Easy transfer cable: Will not complete transfer to new computer.
    Genius:
  • 3,587 Answers
That's usually a cross over cable, and it's not the same as other ethernet cables..check that first to make sure it's the right one.
Posted on Mar 09, 2008
Just got new HP laptop and i'd like to transfer photo's and some files from my old HP desk top computer. What do I need to do this?
If the old computer still works, see the following. Otherwise look for the * for a solution further below. If the old desktop has Windows XP SP3 or newer, you can use the easy transfer wizard. It is included in Windows 7.
If the old desktop has a network connection, you can use an ethernet switch to create a network to share files. Once both computers recognize the switch, set up a network. If you have Windows 7 on one computer and do not have it on the other, do not use the Homegroup network. This may come up automatically; otherwise, use the Network Control Panel and add a network. Start the Easy Transfer Wizard and set this computer as the new computer. There may be an option to get the Transfer Wizard to copy and install to the old computer. Note the code for the Easy Transfer Wizard. Then install the Windows Easy Transfer Wizard on the old computer and launch it. Set this computer as the old computer. Use the code given in on the first computer to synch the transfer. Go through the settings to select the files to transfer and then start the transfer. Prepare to wait a while for the transfer.
If you can't use the Easy Transfer Wizard, set the hard drive on one computer to Share (click Computer (My Computer) and right click on the hard drive and select Properties. Then choose the Sharing tab. Enable Sharing by clicking the Share button.) On the other computer, map to a network drive and locate the Shared drive. Drag and drop the files to the new computer.
If you already have a network connection to a cable or DSL router, you will be asked about "New network found" and to define it. Make sure to make it the home network on both computers. (If you were directly connected to a cable or DSL modem, then you will again get this question. Note the switch will not let your computers talk to the outside network without a router though.)
(Alternatively, use a cross-over ethernet cable with the direct cable networking option.)
Other options: use the Microsoft Easy Transfer Wizard to put the photos and files on a DVD, external hard drive or flash drive with sufficient capacity. You may need to download and install this program to the old computer. For the optical drive option, you need a DVD-RW drive on the desktop and a DVD reader (minimum) on the laptop. (You can use an external optical drive, if you have one.) Another option is a USB file transfer device. Some of these come with the Easy Transfer Wizard on their install disc.
*If the old computer will not turn on, take the hard drive out of the computer and use a USB to IDE/SATA adapter. Follow the directions for the device and attach it to a USB port on the laptop. See if the drive mounts (is listed when you open the Computer File Explorer). Then drag and drop the files from one drive to another.
Note you may need to change the owner of the files on the new computer. (This doesn't apply with the Easy Transfer Wizard if the old user is made equivalent to the new user in the setup of the wizard.) To change the owner, right click on the file in the File Explorer and choose the Security tab. Select the Advanced settings.
I hope this helps.
Jun 30, 2012 | detto intellimover usb data migration kit...
Tip
Migrating XP to Windows 7 (Using your Network)
If you are thinking of buying a new PC and trying to replace an old XP system to a new Windows 7, you might want to transfer your old favorite files to your new computer. Either transferring through a Easy Transfer cable, Network, or via USB
This procedures assumes that your old XP is still working and connected to your home or office network. and your new Win 7 is also connected as well to your networkBoth of your system and computer must be connected to the same network, either in the office or home, because it is easier to transfer files in this way, effectively and efficiently, this is practical than using USB flash drive or any external disk, though the process is similar.
Ensure that you have the Win7 InstallationDVD, or the Easy Transfer Software fromMicrosoft website, ready to be installed on your XP system. but be aware this is for 64 bit version system only, please visit Microsoft website search and download Windows easy Transfer and select "x86" in the file name for 32 bit or 64 bit, install this the same way you've done with ordinary software. In your Win 7 however, this software is automatically installed so do not bother yourself.
In this instance you will be asked if whether you want to transfer your whole data from all user accounts or to just specific user only, in this process you can also select specific files to transfer, but in order to transfer all accounts, both of your XP and WIN 7 must be logged as an Administrator.
So this procedure is Migrating through NETWORK, the other two procedure is Easy Cable Transfer and USB, external Hard disk.
1- Prepare both systems and ensure both are connected to the network and working, Start the XP computer and log in as an Admin
2- IN XP , Open up the and start the Windows Easy Transfer DVD, and look or browse for SupportMigwiz. if you have downloaded this simply select Start> All Program> Windows Easy Transfer for Win 7, it will load automatically. Simply read the screen for additional info and click Next
3- A new screen pops out and please select a Network as an option to transfer
4- Click This is my OLD COMPUTER, Still in XP Windows Easy Transfer will then generate a password for the transferring process, because in order to transfer files through the network you will be required to enter a password (record the KEY)
After you enter the key, at this time Windows Easy Transfer makes the connection and scans the Windows XP system's contents and components. Once this is over, you can practically choose which data you want to transfer, or you want to import, just like customizing the items you wish to transfer. After you have decided which is which, click Transfer, then a progress bar will appears the process occurs.
The final screen will then show up indicating the process is complete. Confirm to see if the file you have chosen was actually transferred, then close all window, including the Easy Transfer Windows.
Restart your computer, please. Congratulations!
on Jan 08, 2010 | Computers & Internet
When you transfer files from an old computer to a computer already in use with a Belkin Easy Transfer Cable, are the files on the destination computer deleted/overwritten or is a new, different, seperate...
It will usually ask you for permission to override and if it doesnt default is usually set that it will rename itsself by adding a number at the end. For example if u transfer a picture called familyphoto to a computer that has it already. It will default rename to familyphoto(2).
Oct 15, 2011 | Belkin Easy-Transfer Cable for Windows XP...
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I have a belkin easy transfer cable. How do i transfer photo's
On the old computer, run Vista's "Files and Settings Transfer Wizard" to write one large file onto the old computer. The "export" file will contain your pictures.
Copy, via the transfer-cable, that one file to the new computer.
Run the "import" function of the Windows 7 Files and Settings Transfer Wizard to read the copied file.
Nov 17, 2009 | Dell Computers & Internet
Transfer XP files to Vista: i am having a nightmare of a time trying to transfer files from my XP computer to my new Vista computer. I tried using an Easy Transfer Cable fo Windows Vista. The driver CD was...
yeah u can use remote desktop connection.which u can find in start->program->accessories->remote desktop.first u need to connect the two computers using lan wire(ethernet cable)....for detailed help ask me on satvir_kambo@yahoo.com
Sep 01, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Easy transfer cable
Too risky as the cable may or may not be configured for two of the same OS.Transference by CD would be a better option.
Sep 19, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Alun Cox
David Payne
David Payne
