Panasonic dvd recorder-freeview, no signal.
I have a panasonic dvd recorder with freeview combined,DMR-REF20DEB was working fine until this morning, put it on, tv etc. the picture came on but ** sound, turned it over and the picture disppeared and a ** signal report appeared. checked all leads and aerial etc. all fine, i even checked with a**ther freeview box, and it worked fine, the dvd is working fine, just the freeview aspect of it .
    Top Expert:
  • Audio Player... Master
  • 27,148 Answers
Check the signal from your aerial.
Posted on Aug 12, 2017
SOURCE: Need to connect the following: Foxtel
how can i recover my dvdrecorder's HDD?
Posted on Mar 09, 2008
Mark_Webber
  • 472 Answers
SOURCE: Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Posted on Apr 14, 2008
VOTIT
  • 2071 Answers
SOURCE: DVD no signal HDMI
Loose or crack or cold solder joint holding the socket of HDMI.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the TV turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Good luck;
Posted on Jul 16, 2008
SOURCE: panasonic DVD Recorder DMR-EX77EB says
I restarted 'Auto setup' this deletes the channel settings (which had presumably been corrupted) and re-installed them from the incoming signal.
alexanderosb
Posted on Sep 01, 2008
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Posted on Sep 28, 2008
Panasonic DMR-BS750EB recording Help needed
I also have the DMR-BS750EB its connected to a panasonic plasma via an hdmi cable and also scart lead so that i can use the tv freeview tuner to record as well and it works just fine if you still have the user manual check the advanced record features for external link or down load the user guide from panasonic. I have had mine since november and had no real issues ... except the ones ive caused from mis interpreting the instructions cheers Alex.
Feb 17, 2010 | Panasonic Televison & Video
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
DMR-E55
Should do.. after all it is only going to record signals OUT from the TV to the DVD recorder IN... as long as it is wired up OK it should be OK. Wire either Component, R,G, B or Audio Visual, .R, W, Y.
Feb 03, 2010 | Panasonic DMR-E55 DVD Recorder
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
I cannot get any tv channels though my panasonic
This model only has an analogue tuner so wont receive anything if the analogue signal in your area has been switched off. either buy a new new with a freeview tuner built in or just use that one in conjunction with a freeview box.
Dec 02, 2009 | Panasonic DMR-ES10 DVD Recorder
Can not get any digital progams now that I have retuned my panasonic dmr-ex75eb dvd recorder. Am not receiving any digital signals
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Sep 30, 2009 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
132 people viewed this question
 Grubhead
Grubhead
