Question about Kenmore 24032\24036 Top Load Washer
Sloppy play in laundry drum
Can someone help with this problem: When loaded with clothes, it seems like no matter how I distribute the clothes, the washer clunks like its unbalanced. Do I have a loose drum or something? Can I fix it relatively easy?
Appreciate any help from you techies!
While the washer is washing the drum is sloopy and makes a noise.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    what's it like when it's empty?
  • 30 Answers
It sounds like the main drum bearing has gone you should call a local engineer to confirm good luck
Posted on Mar 10, 2008
Drum banging when it spins
Two things might be in play. First, the washer needs to be level and on stable surface. Next the laundry needs to be fairly evenly distributed in the tub. I have had this happen, and sometimes it just needs releveling, particularly if you had a heavy unbalanced load.
Feb 22, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Drum makes a noise when spinning
Seems to me washer is off balance clothes are not evenly distributed or something may have become lodged hindering the spinning of the drum OR factory defect if recently purchased. Hope this helps
Mar 21, 2011 | Zanussi ZWF1420W Front Load Washer
I have an Lg turbo drum machine it has filled up and done the wsh but then gone ue overloaded but i have removed all the clothes and it still wont empty the water or spin
"UE" Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum. Move the washing around inside the washing machine to create a more even distribution of weightif you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
Jan 26, 2011 | Washing Machines
My washer jumps and moves accross the laundry room during the spin cycle. We have made sure it is totally level and made sure there aren't a lot of clothes in the washer at one time.
You have a wash Load Unbalance, as you have done, ensure the clothes are evenly distributed in the drum, so it is either that or the balance weights have come off the drum inside...I have also seen it when a bearing has gone bad. probably going to have to get someone to have an inspection.
Feb 04, 2010 | Kenmore HE2 Plus Front Load Washer
When water goes in,then it starts leaking from underneath-have checked for blockages.Spin seems slow and not washing clothes?? Then dial seems to go around sometimes on its own???Help!
has the bearings been replaced recently or may need replacing it has been known that should a bearing get a bit sloppy then the drum rubs on the outer caseing wares a hole in it the outher casing is plastic
Jan 16, 2010 | Indesit W 123 Front Load Washer
Hi my LG 8kg top loader washing mashine says UE and wont drain
UE code means an imbalance error. Either the load is too small, the appliance is tilted, laundry is gathered to one side or a non distributable things are put into the drum.
Make sure the unit is placed in level location and distribute the load evenly inside the drum. Do not load the unit with on-distributable items.
Oct 19, 2009 | LG WFT1071TP Top Load Washer
Musty stale smell
HI thanks for your question. ALL front load washers have the same problem.MY solution every wash use 1 cup of vinegar in time will solve the problem. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | LG WM1814CW Front Load Washer
We have not heard back on this in about a week. I'm presuming it's now fixed?
Mar 06, 2008 | Roper RAB2121KW Top Load Washer
Black marks on clothing at completion of drying cycle
Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
Jul 06, 2007 | LG DLE2514 Electric Dryer
My washer shows UE code
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
Apr 21, 2007 | LG WM-2077C Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
195 people viewed this question
Sal De
fordexpert
Robert Rankin
