Question about Technics SL-1200MK2 Turntable
** sound Bought a "gentl;y used SL-1200MK2 without cartridge ort needle. Bought compativble needle and have it wired correctly in headshell. Screwed it in and all cablle connections correct to receiver. When playing a record, I don't hear sound. Suggestions?
  • 515 Answers
First and foremost, make sure you plug into directly to the PHONO input of your receiver. If your unit does not have a PHONO input, then you wont be able to hear much coming from the unit. The PHONO input is a pre-amplified input, and this turntable requires an amplified input in order to transmit it's signal correctly. Just using an AUX or LINE IN will not have enough power to increase the signal of the turntable. You have the option of purchasing a PHONO PRE-AMPLIFIER (range in price from US$15-30), or purchasing a new receiver with a PHONO INPUT!
If you have it connected to your phono input, and still no sound, your turntable may have either faulty RCA cables (red/white cables), or a bad tonearm - in either case will need to be replaced.
Hope this helps.
Posted on Mar 21, 2008
The needle is broken off can it be fixed for less then the turntable cost?
Yes it can. On the head of the arm if you look carefully where the needle (to give it's correct name -stylus) is. What it fits into is a cartridge. If you can see letters or numbers on it that will be the type. If you put that into Google it should find it. You should find if it is possible to buy the stylus with or without the cartridge. Though it's often cheaper to buy both. The cartridge will either be screwed onto the head or just clipped on someway. You will find four wires attached to the cartridge. These will have to be removed if you have to replace the cartridge. Make a note of how each wire attaches to the cartridge. As long as you can get a cartridge to fit the headshell you can use any magnetic cartridge for the job. All you would need to do with a different cartridge is adjust the weight to apply the correct pressure to the stylus.
If the cartridge doesn't have any number etc on it, put the make/model number of the turntable into Google adding cartridge/stylus.
Jan 05, 2011 | ION Audio Vinyl Recording Turntable
Replacement Cartridge and stylus for Technics SL-D1 Technics Turntable
That turntable, like many others, has an S-shaped tonearm with a removeable headshell. You can use any standard screw-mount cartridge as a replacement. Which one you buy depends on what you want to spend and your intended use. If you're a DJ you'll need a more rugged cartridge than you do for listening at home, for instance.
One company I buy lots of parts from is Parts Express. Here's a link to their styli/cartridges pages. If you have the original cartridge and stylus, you can check if they have the exact replacement. Otherwise you can browse the other choices. You can find many other sources as well, and you may have an audio shop or musician's store in your area who stock cartridges.
Jan 02, 2011 | Technics SL-1200MK2 Turntable
Just bought a new Shure high performance stylus for my Technics SL-1200MK2. After a few weeks of use, while a record is playing the volume on the left channel will drop significantly. If I take the...
it could be two things:
1.the tone arm wires that connect to the head shell (blue-red-green-white i think)
2. the needle arm has twisted round
Put it on the other deck if you've got one & see if it does it.
look right at the end of the needle tip,& see if it's straight & pointing down, if not carefully twist the needle arm round until it is,& push it into back in to the cartridge a little bit.
Sep 30, 2010 | Technics SL-1200MK2 Turntable
Sl 1200 mk2 no sound comming out new needle
It sounds like the rca (phono) leads also check your cartridge.
Dec 16, 2008 | Technics SL-1200MK2 Turntable
Phono Preamp buzz
Don't forget to ground the ground cable from the turntable.
Sep 15, 2008 | Technics SL-1200MK2 Turntable
Uh, hold the black headshell with one hand. With the other, twist the bumpy ringlock on the tonearm gently clockwise. Slide the cartridge out. You should be facing the TT.
Sep 01, 2008 | Technics SL-1210 Turntable
What cartridge do I buy for this turntable
You should get a headshell first of all. Into the headshell you install the cartridge. I would get a Technics headshell just because it is of the same brand, and I use a SHURE M35X cartridge which is mean for dance or electro music. The headshell is your option but the cartridge should be matched up to what type of music you will be playing. Good Luck
Sep 01, 2008 | Technics SL-1200MK2 Turntable
No signal from the Left output + Tinny sound
1. Assuming there is no problem with your amplifier of input cable, the headshell/tone-arm needs rewiring. This is very thin flexible wire and not easy to do, but can be done if you are careful.
2. Turntables require a special input on your amplifier which has a frequency response that is suitable for them. If you connect a turntable to an ordinary input, it will sound tinny. If you don't have a turntable input (known as a phono input [from phonograph]) you will need to use a preamplifier with your turntable.
Mar 05, 2008 | Technics SL-1200MK2 Turntable
Sound problem
first thing to do is take the left and put in in the right, do you get sound on the right?
now take the phono cartridge wires and move the left to the right and right to the left does the sound move or stay same place. if they move with or not tells you if the cartridge is bad or phono plugs. if they dont move it's the phono plugs if the does move it's the cart.
Jan 28, 2008 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
196 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
