Question about Acer Aspire 3000 Notebook
Acer laptop manual
Looking for on line mauual showing disassembly/assemble of acer 3000 notebook computer.Replacing the power pin.
  • Anonymous Mar 29, 2014
    Laptop showing temp of 90% C on acer tm8372
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
Often the pin is soldered in three places to the motherboard. The repairs aren't that hard to do yourself if you are careful. Check some of the replacement pin suppliers on google and see if one for your computer is available.
If you decide to do the repairs yourself I suggest using a digital camera to document your dis-assembly process. The picture will make it easier when you go to re-assemble the system. When you get it finished, to make sure it doesn't happen again, get a CRD (Cable Retention Device) like this company sells. It takes the strain of the power pin.
Posted on Apr 25, 2008
    Genius:
  • 3,587 Answers
That's on the motherboard by the way..and usually is a whole board replacement issue.
Posted on Mar 09, 2008
HOW TO GET THE BACK OFF
Break it off..........
In order to take the Base Enclosure (Bottom Cover) off, you would have to break it off.
The Acer Aspire 5000 series of Notebook PC's, disassembles from the Top down. When you are done you are looking at an empty Base Enclosure,
http://www.ebay.com/itm/ACER-ASPIRE-3000-3004-ZL5-5000-LAPTOP-BOTTOM-CASE-COVER-LOWER-BASE-3AZL5BATN05-/181127078788
You have to;
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Harddrive Compartment Cover, Harddrive, Memory Compartment Cover, Ram Memory, Wireless Module, Wireless Antenna wires out of laptop body, Optical Disk Drive, (DVD drive), Display Assembly, (LCD Module), Keyboard Cover, Keyboard, Palm Rest Cover, Motherboard, and so on..........
Then you have the Base Enclosure. (Bottom Cover)
WEAR an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Acer Aspire 5000 series of Notebook PC > Service Manual (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the paragraph that starts with Aspire 1200. (1200 in Blue)
Drop down to the 6th line (4920G), scroll across; and click on the blue -> 5000
For additional questions please post in a Comment.
Regards,
joecoolvette
May 02, 2013 | Acer Aspire 5000 Notebook
How do i replace the cooling fan on my acer aspire 9303?
The Acer Aspire 9303, is part of the Acer Aspire 9300 series of Notebook PC's.
I have good news, and not so good news.
Good news:
This is a link to free Service Manual,
Drop down to the 'paragraph' that starts with Aspire 1200. (1200 in Blue)
Go down to the 13th line (8390Q), scroll across, left-click on 9300.
[ Ignore the following if you are aware;
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (9300), it may take up to 30 seconds to download.
After the file has downloaded, bring your mouse to the bottom of the page.
The 'ghosted out' Navigation bar will appear.
Go all the way to the right, and click on the Adobe PDF icon.
(Looks like a three pointed 'star' ]
Start on Page 69. (PDF file page number at top)
Direct information for removing the Fan Assembly, is on Page 78.
Not so good news:
The Display Assembly has to be removed, and the laptop disassembled down to the motherboard removed, to access removing the Fan Assembly.
1) Remove ALL Power. Remove the AC adapter (Charger), and Battery.
2) Advise use an ESD wrist strap, and connect it's alligator clip to a good ground source.
Average cost is around $3 to $6. Cheap insurance, so you do not Static shock, the delicate hardware components inside your computer.
Do not wear one, and have it connected to a good ground source, and you can use the laptop for a doorstop.
3) Use a multi-compartment container, for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws. Advise Do Not mix them up.
4) If this is your first time, make a record as you disassemble. Make notes, and drawings, and/or use a digital, or video camera. Use good lighting, and make legible notes.
Nice to have a Service Manual, but even nicer to have your own personal record to refer back to, in case you are interrupted.
Regards,
joecoolvette
May 23, 2012 | Acer Aspire 9300 Notebook
Exploded diagrams of acer5553
Exploded diagrams?
This means to me you may wish to have the Service Manual.
Has Disassembly, and assembly guide in it.
This is for the Acer Aspire 5554, which I believe you'll find will work for the 5553,
Go to the 'paragraph' that starts with Aspire 1200. (1200 in blue)
Go down to the line that starts with - 5332. (7th line down )
Scroll over, and left-click on - 5554
Disregard if you are aware;
After you click on the file name, (5554), it may take up to 30 seconds, before the first page comes up.
Done.
Doesn't use the same Intel technology that the 5554 does.
It does not support Intel Core i processors.
It does not have an Intel HM55 motherboard chipset.
Case, and disassembly looks the same.
Disassembly guide for the Acer Aspire 5534, also looks the same,
http://www.insidemylaptop.com/how-to-dismantle-acer-aspire-5534-series-laptop/
Copper contact pads you short out to rest the BIOS password?
Ummmm, no. No info.
http://support.acer.com/acerpanam/notebook/2011/Acer/Aspire/Aspire5333/Aspire5333sp2.shtml
If what I have given is not what you seek, simply state in a Comment, as to what it is you do seek.
Regards,
joecoolvette
May 04, 2012 | Acer Computers & Internet
Acer Aspire 5735Z Replacing the Power Jack
http://www.eservicemanual.info/index.aspx?b=Acer&m=ASPIRE-5735&view=1240994504
This is pretty simple, go to this website above and download your service manual, it shows how to disassemble and do what you want.
Jul 14, 2010 | Acer Aspire 5735 Notebook
How do I turn on the wireless in the notebook acer aspire 3000
Look on the front edge of the laptop, you will see what appears to be two clear looking buttons, the button to the left of the audio jacks is your wireless switch, the button to the left of that is your bluetooth switch. Below is the link to the user manual for that laptop, you will find this info on page 2 of the Acer Tour Chapter.
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS3000-5000_UG_ENG.pdf
Jun 16, 2010 | Acer Aspire 3000 Notebook
Looking for a manual for this comp want to plug a microphone in but one i bought doesn't show up on screenwant to make sure have pluged in to the proper place
Please use this download:
Acer Aspire 3000 3500 5000 service manual
Acer Spire 3000 5000 user guide
There's only one place you connect the microphone, and that would be the "red" jack on the front of the unit. The unit however should have a internal microphone as far as i can recall...
May 28, 2010 | Acer Aspire 3000 Notebook
Can not power up ACER 9410Z laptop after replacing memory
Try to remove one and restart with just one installed,if it restarts,Let it completely load,shut down and reinstall the other one and restart again.
May 31, 2009 | Acer Aspire 3000 Notebook
Acer 3000 - disassembly instructions in order to change out dc computer connection
goto GOOGLE.COM
then write the same thing as below
" hardware structure of acer aspire 3000 laptop"
that's it...
Dec 01, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
350 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
