Question about Whirlpool AWM5145/2 Front Load Washer
GE washer only works on spin
I have GE washer. when I turned it on today we found out that ** water is coming into the washer, I was looking around it only woks on SPIN
thank you
    Genius:
  • 3,587 Answers
That's a control panel failure...will need a service call, unless you're feeling particularly handy
Posted on Mar 09, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
It's been leaking----found water on the floor today. It won't spin when set on the cotton side, but it will spin on the delicate side.
retire the machine. GE's are junk. they fallapart in 5 yrs. the seals on your transmission are most likely leaking. Brake on trans not working.
Buy a whirlpool.
Nov 17, 2009 | GE WBSR3140DW Top Load Washer
Water will not shut off in washing machine
Check to load size selector switch, sounds like tube came off of it. The tube goes from switch to bottom of tube, tells machine what size load and when to turn off water.
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
GE WJRR4170 washer comes out of overflow tube on super load. It does not on Large load size. I have the front off and can see a large difference in water level from large to super size. Is this adjustable?
I have a 2005 model GE washer that would overfill only on SUPER size load. After looking around on the web, then inside the machine, I checked the tube from the tub to the switch, no problem there. Then I found an adjustment screw on the load size selector / pressure switch (all one piece). I moved it one turn clockwise, then ran a test cycle. I got lucky on the first try... no more overflow, the water comes up just above the top holes in the tub. I hope this will help others.
Mar 15, 2009 | GE WVSR1060A Top Load Washer
GE WBSR WASHER WATER OVERFLOWS
He probably disconnected the water level sensor when replacing the belt or the timer is dead.
Check for any unconnected sensor or check if the main program button is turning propely..
cheers
Dec 20, 2008 | GE WBSR3140DW Top Load Washer
Model #:WBSR3140DWW
My GE washer will not agitate or spin. Will fill up with water but wont spin. Looked at motor and it has a green light that flashes about every second constantly. I can turn the pulley both ways. Does anyone have any suggestions
Oct 18, 2008 | GE WBSR3140D Top Load Washer
How do you reset the washer?
I have a GE WBSR3000GWS Model and it stopped spinning at one point as well. My service guy came out and did the procedure below and reset it with in minutes.
How to Reset your GE Washer :
1. Turn the dial like your going to wash a load but do not pull the knob.
2. Unplug the washer from the wall and wait for 30 seconds.
3. Plug the washer back into the wall.
4. Lift the lid 5 times to at least 6 inches high. Open/Close within 15 secs.
5. Pause… You should here a click. If you do not, then repeat 1 – 5 again.
6. Insert a towel or garment into the washer and then pull knob to start the wash cycle.
7. Check the wash cycle to make sure the washer is agiating and spinning during its cycle.
GE Answer Center : 1-800-626-2000 opt 3 - for more information
Lale
Jun 20, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool AWM5145/2 Front Load Washer Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
