Question about Tablets & eReaders
To know good hard disk
Hi i want to know which is good hard disk and good ram
which is fit to my system
cost of these two things
i want to bye 160gb hard disk and 1gbram
my system configaration is
80gb harddisk
512 ddr1 ram
d101ggc mother board
intel pentium 4 processor 2.80ghz
I think that Western Digital Hard discs are reliable with affordable cost. But if you put a little money more Seagate offers better stability.
DDR1 or SDRAM?
Either or else I think Transcend is your solution and it is better to go to 2GB of Ram to see better improvements.
Posted on Mar 11, 2008
What do i do when the games on my computer are very slow.
Ok, there are many reasons why the games on your computer may be running slow.
First, if the game is a downloadable game or a game uploaded via a Disc purchased from a store than your computer may not meet the system requirements to run at the normal speed.
To correct this, you can try a few things that wont cost you anything.
Option One:
1. Click the Start Menu.
2. Click on ALL PROGRAMS
3. Select Accessories
4. Click System Tools
5. Click DISC CLEANUP
This will compress and remove any unnessary files such as temporary internet files and trash.
This can open up a significantly amount of space on your computers hardrive which often allows games to run at a faster rate.
Option Two:
5. Click Disk Defragmenter
This will defragment and compress and files on your computer that are currently using more space than they need to. This can occassionally be a significant aid in speeding up a computer.
I advise you to complete both of these initial Options prior to using my next Option:
Option Three (COSTS MONEY):
1. You can purchase a new video card (Best Bet is to buy from the manufacture of the computer)
2. You can add RAM to your computer if it is a desktop. (Often, desktops can have more RAM added to them, or a second Processor/ Video Card in order to run faster)
Hope this helps.
May 13, 2011 | HP Tablets & eReaders
I ave a toshiba m200 that is taking to long to operate and when it does i stuck and refuse to function in any way!! i have no idea what is the problem and am trying to retrieve my work and upload it in a...
Hi,it is possible that the resultant cause the problem is your hard drive(caused by the hard disk failing to be READ from or be WRITTEN to,in this case be READ from),or one of your Memory modules is failing,so first of all try swapping or switching the RAM modules from one slot to the next,one at a time,if system is still slow,take out your hard disk,get a converter,slave hard disk to another system copy your files out and get a new Hard disk.
Jan 04, 2011 | Toshiba Portege M200 Tablet PC
My computer says no operating system
Check your BIOS to see if it's trying to boot to the floppy drive, or CD instead of the hard drive.
Try to boot to CD and see if it runs.
If you can get to CD, reinstall Windows and choose Repair, which will only copy the operating system files, and leave your data files intact.
If all of that doesn't work you may have had a hardware problem with the controller, RAM problem, power surge, or file corruption from any of those, or from a virus. In the end, the last extreme is to do a reformat and reinstall with fresh Windows and start adding your programs back on, one at a time.
Remember to keep your essential data backed up... at least once a quarter if you can! 8^)
:o)
Jan 02, 2011 | Gateway Tablets & eReaders
I want to add RAM to my Toshiba Portege M405-S8003 but I can't find the memory slot. The only things I see underneath my laptop are the battery pack, a square-shaped slot (when I opened it, there's a paper...
Hi,the Ram slot you are looking for is underneath the keyboard,if you have expertise on uncoupling and re-coupling a system then proceed,if not take to a qualified technician to that for you wont take any time.
Jan 01, 2011 | Toshiba Portege M405-S8003 Tablet PC
I have a tx1410 touchscreen hp laptop I have a black screen when i turn on my computer and all the buttons are lighting up. Everything works but the black screen. I put a dvd disk to boot it up and then...
First you need to check if you did not have any flash drive or device attached to your laptop when you turned it off. Because if you do, your system will not booth completely, you will only be having a black screen, and to solve that, you just remove your battery and insert in back then try to turn it on.
Ensure you have the battery fully charged. Then turn it on. If that does not help, then the problem could be a hardware problem, which could be that the module is faulty and the screen is not lighting up or the hard disk is disconnected or the RAM is not connected properly.
The module is like the flex on the laptop that assists the information from the motherboard be read on the screen. So if it is faulty then you will not be able to see anything.
For that, you need to open it up and replace the module. If it is the hard disk, just tighten the connection and the RAM too, then try to couple it back together and turn it on.
Try to hold down control+alt+delete to see if the task manager comes up, if it does, then you know it is not the module, then you select task manager and run an operating system disk, to format your hard drive and run a new operating system.
These are a list of most likely problems that can affect the screen of your laptop.
If you are not familiar with such technical activity (loosening the laptop), i will strongly advice you seek technical assistance from a professional, to avoid shock or further damage in the unit.
Take care and good luck
Oct 18, 2010 | HP Pavilion tx1410us Tablet PC
Hi, i bought sdram for a laptop online, i scanned the computer first to check what i needed. i got the ram through, fitted it and now the computer just beeps and wont start, please help
If the RAM is not properly seated in the slot, this can occur. Check the RAM alignment and make sure they are pushed all the way into the RAM slot. Be careful because it should not take much force to push them in, and the notch in the stick will line up with the slot on the laptop.
Could be the RAM is bad or is the wrong type for you machine, which you can test using a boot disk and a program like Memtest86. http://www.memtest86.com/download.html
Also, some laptops will require you to confirm the new amount of RAM in the system BIOS so you may need to go in there after it's properly seated.
Mar 17, 2010 | Tablets & eReaders
Can I install windows 7 on a panasonic toughbook cf-18 tablet
I don't thank they have it out for tablet yet. Wait a bit and they should.
Nov 11, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Reset bios
There's no need to reset your BIOS, only you do is to set in your BIOS Setup to boot priority like for example First Boot Priority is your CD/DVD Rom Drive, if you got some Bootable System Disc then the Second Boot Priority is your Hard Disk Drive. Good luck!
Jul 26, 2009 | Compaq tc4200 Tablet PC
Computer running slow
Hi;
Running slow few possibilities:
You need more RAM memory -cheap to buy off ebay,
Hard disk space running low - cheap again on ebay,
If its running slow because you are running a high graphics application then you may need a better Graphics card. But ultimatley it will com down to those and finally your CPU and motherboard.. but by then it would be ccheaper for you to buy a newer system.. Again thats cheap from ebay too.
I hope this helps, please don't forget to rate my solution.
Thanks.
Mar 15, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Tablets & eReaders Logo
228 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
