Question about Lexmark All-in-One Printer with PictBridge
Lexmark 1200 does not recognize black ink
Installed new blank ink cartridge and will not print in black...yes, did take off the tape at the bottom. Help
  • Handsoffate Mar 10, 2008
    New Lexmark x1290 printer. VISTA 64 OS. New 2.0 USB cord.
    BLACK simply wont work. Tape is off. REbooted, installed new lexmark vista 64 drivers (from lex site), waited for prompt b4 putting in usb cord, fully installed.
    There IS inc in the black cart as I saw it come out when cotton was pressed next to the btm (qtip).
    There were some warning signs during installation but I think it is normal (Vista auto installed shut down by the lexmark driver installation)
    "Generic USB HUB Ready to use
    X1200 series Wizard cancelled by user
    Lexmark 1200 series Wizard cancelled by user"
    This thing works FINE if I tell it there is NO black inc cartridge....but there is, and I dont want to pay for more expensive inc to find out if thats the problem (1/2 the cost of the printer = black inc cart)
    Genius:
  • 3,587 Answers
That's good..after replacing a cartridge, it's highly recommend to do a clean and re calibrate...you can do this from front panel.
Posted on Mar 09, 2008
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Installed black print cartridge will not print now?
nope, there should be no tape on the cartridge. This is preventing the ink from coming out.
Jul 30, 2008 | Lexmark X6170 All-In-One InkJet Printer
Lexmark X1270
Does the printer attempt to print? Did you replace the black or colored ink? If it was the black ink will it print in color?
If it prints in color, check the black ink cartridge for tape residue on the gold contacts. The blue tape will sometimes leave the adhesive on the cartridge and not the tape. It cleans off easy with a soft cloth.
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printing out blank pages
Had the same problem and found that actually I didn't have the cartridge installed correctly. Make sure that the blue tape on the "bottom" of the cartridge came off when you pulled the tape off to install the cartridge. It is a blue translucent film which covers the port on the bottom and wraps around the front side about 1 1/2" long. On my black cartridge it didn't come off when I pulled the tab. This probably isn't the problem you're having but worth checking. Good luck.
Apr 04, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printing blank pages
Blank Pages Printed
Remove the protective tape from the cartridges:
With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
Remove the cartridge(s) from the printer.
Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
Clean the cartridge nozzles:
Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
Clean ("wick") the cartridges:
Remove your cartridges following the instructions in your User's Guide.
Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Mar 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
PRINTER
The following link provides the user guide and setup sheet for your printer. They explain how to change the ink cartridges.
http://www.lexmark.com/publications/eng/1200/index.html
Dec 25, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
441 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
