Kitchen Ranges
Problem for Kitchen Ranges
Generic problem for all Kitchen Ranges
Amana Big Oven Will Not Heat
By shallen on Mar 09, 2008
my oven will not heat all the way
Same Problem
Mar 28, 2008
-   My Amana "the big oven" is all electric and requires a long time to preheat. Also have to set it up to about 550 for a bit until it gets in the 400 range, then back off to try to keep it around 450. what can I do to fix this myself?-   phprrt
Solution #1
posted on Mar 10, 2008
Somewhat Helpful)
aborcass
Rank: Guru
Rating: 89%, 2424 votes
slow to preheat??? long cooking times??? smell gas while in operation???. all signs of a bad oven ignitor retails for about 60-65. easy enough to replace reomve the lower panle of the oven itself and you'll see the ignitor right there 2 ***** mount that to the bake bar and pull it out, unplug the wire harness, plug in the new one and remount.Start baking
Was this helpful?
Yes
No
Popular Solutions for Kitchen Ranges
Questions and Unsolved Problems for Kitchen Ranges
Answer
which brand Dual fuel slide in range is the best?
Answer
I need a 30" slide in dual fuel range. I currently have a jennair with downdraft in that spot,... (More)
Answer
model loo6008 I need to locate the instruction manual
Answer
How much is a KB3300JS Cooktop replacement, and do you guys sell them?
Answer
how do you remove light cover on a double oven to replace light bulb above cook surface
Describe your Kitchen Ranges problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Range Experts
Top Range & Oven Repairmen
in , MD
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
