I HAVE A CARB PROBLEM AS I DRIVE THE HONDA A LINE ASSUMEING IS A OVER FLOW DISCHARGES I CLEANED CARB BUT CONTINUS TO FREELY SPIT OUT FUEL IM STUMPED
The float needle is stuck open. Typically the needle can get a speck of dirt or the float adjustment arm is not properly aligned. The arm should be able to close the needle at approximately 90 degrees. Remove the float bowl and look at the carb from the side and adjust the arm to seat the needle when the floats are about where they would be as if the bowl were full of fuel.
Good luck.
