Question about Whirlpool Duet GHW9150P Front Load Washer
Drain problem Hi, Saw that you've got the best answer for this problem. Can you help me? Thanks!
    President:
  • Whirlpool Master
  • 2,651 Answers
You can gain acess to the pump cleanout by removing 3 torx 15 screws from along bottom of front panel. justbehind the panel youl find the "bttoun trap. unscrew it and chances are youll find baby socks, bra underwires, etc... )somethings blocking the pump from orkin proerly, be warned scoop water out first, and tip unit back if possible. when oyu unscrew the pump clean out all water above will be coming out
Posted on Mar 12, 2008
I've dropped my samsung s8000 into a muddy lake about 3 hrs ago, I've dried it as best I could after fishing it out, its worked as I have received and made calls, but it's having trouble...
. you need to open it up to the best you can and dry under the sun for hours or under **** heat. that should do.the heat dries up the moisture in the board. thanks
Jul 29, 2011 | Samsung Jet S8000 Cell Phone
I'm in search of the *main body* for a vintage
You may have better luck finding another saw, but check into this site, and post your request on their bulletin board. I've had some good luck with them in the past.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 24, 2011 | Delta Saws
Looking for a front and rear locking fence for this table saw also owners manual,any help would be appreciated.THANKS BOB
Please go to this link where you will find a list of available parts and a downloadable instruction manual for your saw.It looks like the fence assembly is still available, but I recommend you review the exploded parts diagram and compare the numbers found there to the parts list to confirm that you have ordered all necessary parts before shipping.
Jul 20, 2011 | Black & Decker BDTS200 15-Amp Table Saw...
I bought a Craftsman radial arm saw years ago at an auction. No where on the saw can I find a model number. There is a model number for the motor. the number is KS48 DG-214. Can you help?
You might want to have a look at some of the manuals available online at this site. Perhaps there is something there of the same general vintage that will help you to answer your questions. I think there is some kind of stamped plate on the back of the saw, either on the column or the table base itself. I don't really remember, and mine is buried into a cutoff table and inaccessible. Otherwise, you could try looking up the motor model number at the sears online site at www.managemylife.com. Good luck.
Jul 19, 2011 | Craftsman 10" Table Saw
I have a pm2000 3hp left tilt saw that i purchased 3 yrs ago but have never used or even set up until today only to find out the tilting mech. doesn't work
I bet the grease has set up and the worm gear is just frozen in place. Have you tried spraying some oil or wd40 or silicone lube into the worm gear, and lubricating the trunnion ways? I can't believe that if you've unlocked the handle lock and pushed the handwheel in the saw won't tilt at all. You can download manuals for that saw from here. See page 14 for more details, or get someone who's mechanically inclined to take a look at it for you. If the saw is new, it has a 5 year warranty.See here for repair or parts info.
Jul 18, 2011 | Powermatic Saws
Instructions for installing BT3000 saw belts
Please see operating manual available for download here. That includes an exploded parts diagram, which may help you get the new belts on. Otherwise, you might try contacting an authorized Ryobi service center and asking for assistance. I'm afraid I've never worked on one of those saws.
Jul 10, 2011 | Saws
I have a 1587 AVS, changing the blade, I turn the blade into the proper cutting position and turn the nob but the blade will not tighten.
You have to pull up on the knob while you tighten it, without pulling it off the saw. A bit tricky.
Also helps if you gently pull out on the blade a bit as you tighten. See this rant of mine on the same topic, which includes a link to the online manual.
Best of luck.
Apr 29, 2011 | Saws
How does one replace the pin in a sliding compound miter saw? The locking pin on my saw has broken, I have a replacement pin, but I can not figure out how to replace it. Can you help?
I"ve never had to replace one, but here's an exploded parts diagram that shows it has an o-ring on it. I'm guessing its a friction fit and maybe you can just knock it out with a punch or drift, or maybe twist it out with a pair of vise grips...but I don't have the saw in front of me, and can't remember if the back side of the pin is accessible.
Anyway, FWIW, see here.
Aug 22, 2009 | Dewalt DW712 8 - 1/2" Sliding Compound...
Table Saw Blade Won't Cut Straight
Inside the saw, on the end of the trunnion is a stop that is adjustable to zero the saw in to exactly 90 degrees. Either there is sawdust or something accumulated there or it needs to be adjusted. You say you cleaned it out, So you'll need to unplug it an have a look up in there. See how there's a geared piece of steel that moves when you crank the saw over to 45 degrees. Usually there's a bolt or stud with a locking nut on it, either on the trunnion itself or the lower surface of the table top. You need to break the nut loose and screw the bolt in or out to adjust, then crank the saw over to hit it, check for square with a known square, crank it all the way out of the way and readjust, etc. Until you get it right. Make sure to tighten that lock nut when you're done.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 02, 2009 | Craftsman 10" Table Saw
Whirpool refrigerator ,water dips into the fridge compartment from the freezer
It is not supposed to be removed. try flushing some warm water through it.
Aug 01, 2008 | Whirlpool ET1FHTXM Top Freezer...
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
