** agitation just spins
The agitation is **t going back and forth. It is just going in one direction. if you stop the machine and restart it goes in the opposite direction but ** agitation just spinning. Is there a sole**id involved to get this working right?
  • 52 Answers
It may be the agitator directional cogs, aka agitator dogs. If you remove the top "cover" on the agitator, they're inside of there. They are 4 yellow/clear colored rubber pieces with little teeth. If the teeth are gone or worn, that is most likely your problem. Click here to see a picture, and part details.
Posted on Mar 10, 2008
Kenmore 80 Series 110.27802690 agitator barely moving
It's the transmission that's bad. The motor turns one direction to spin and the opposite direction to agitate. The transmission converts the constant belt speed from the motor into the back and forth motion. In the other direction, the transmission stops and the whole system spins.
(I don't suspect you have it set to "delicates")
Jul 20, 2016 | Kenmore Washing Machines
The agitator is only working in one direction so the washing is getting tangled
The top portion of the wash tub agitator is designed to rotate in the clockwise direction. It should be intermittent. Turn stop turn stop ....in its normal operation.
There is a set of plastic cams that allow for this function. Below the top agitator the lower agitator goes back and forth. With a short load the water just reaches the upper agitator. Try short load. Other possibility the tub is under filled try increasing the water level.
26221857-hkbf5riehselkv40qtw2in2z-5-2.jpg Two piece agitator
26221857-hkbf5riehselkv40qtw2in2z-5-5.jpg Two piece agitator.
Hope this helps?
Jun 20, 2016 | Washing Machines
Admiral washer aav7000aww-agitator only spins one direction-doesn't agitate-it stirs the laundry.
Remove the agitator, and turn the transmission pulley, one way, the spin basket will spin, the other way, the transmission spindle should go back and forth. If not, you have a bad transmission.
Here is the transmission to order if you should find it bad.
Sep 26, 2013 | Admiral AAV7000A
The agitator will not spin. It just goes back and forth
The machine has 1 motor rotating in 2 directions. one direction for agitation ( moving back and forth from one mechanism) the other for spinning (squeezing water out of clothes by another mechanism). The problem with the machine is the mechanism for spinning. The mechanism includes the clutch, the brake, the pulley to push the brake open so the shaft can engage with the turing direction from the motor. The part is cheap, but the labor is expensive since the tube has to be out to replace this. This is the idea to know what the serviceman talks about so you don't get rip-off.
Jan 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator does not seem to be moving in the right direction
Yes, you will need to replace the transmission and clutch assembly. your assessment is correct.
Jul 11, 2009 | Washing Machines
Hi I our agitator has stopped turning. It barely will move back and forth.
Set the washer for spin and turn it on.
Does it spin?
If no.
Check the direct drive coupling on the motor.
Mar 08, 2009 | Whirlpool Washing Machines
Agitator spins in one direction
The purpose of the upper portion of the agitator is to push the clothes in a downward motion. As the agitator moves the dogs grab and on the backward srtroke the top portion rotates a quarter turn. In the spin mose the agitator only goes in one direction or your clothes would be torn to shreads.As the washer rotates back and forth, the dogs grab the inner walls of the upper agitator and that forces the clothes into a downward movement to the bottom of the tub. These dogs will wear out. To test whether or not these are bad just grab the agitator while in wash mode. The dogs should advance the top portion easily. If not then they are worn out. To replace them you must remove the agitator and sit it on the floor. Hold the base down with your feet and yank the top upwards. After seperating the 2 pieces you simply install the new dogs and line up the bottom with the top being careful not to break the little tabs on the bottom agitator that hold the top in place.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
