Question about Brother ML-100 Typewriter
Not typing correct letters
I have a ML100. I have been using it for about 6 weeks. Shortly after changing the ribbon I began having correction problems. It would correct the error but the wheel did change any longer without doing control/Q. It would then reset and work fine til the next error. This went on for a week.
A few days ago, without making an error to require "correction" it stopped typing the letters my fingers were typing. This caused me to hit the correction key and then control/Q.It then worked correctly few two to three sentence before going back to typing odd letters, numbers & symbols. I have tried changing the correction ribbon, taking the ribbon out and re-putting in, & I even tried taking the wheel out and puting it back in. I am at a loss. Can you help, before I have to tell my boss that I killed her new typewriter. If you need an email you can use [email protected] (work) or [email protected]
  • 1 more comment
  • carmelcat Mar 10, 2008
    My supply manager agreed with you. What would be a good choice for heavy use on typing titles and supporting documents?
  • Anonymous Mar 13, 2014
    sometimes the 'correct' key works fine and sometimes it will not correct the letter I need it to. but if i type something new and correct it, it works...
I called the Brother's help desk and was given the following advice -- take the wheel out and inspect for breaks or bends on the metal "spokes". If you find any replace the wheel. I couldn't find any, so I was told to replace the wheel and then press controlQ.
After following the instructions, my help desk person asked if it was typing correctly, I tried a few words and told her that they printed correctly but was striking each letter twice. She said the problem was solved, and to call back for any other issues. I hung up and half way through a title it (the original problem) started again. My boss plans to return the typewriter for another typewriter. This is how she will fix the problem.
Thank you for your interest
Posted on Mar 10, 2008
  • 481 Answers
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
  • James Cagle
    James Cagle Mar 10, 2008
    I sell and truly like the Nakajima AE models for office work. The cost is $419.00 and they can be dropped shipped to your office.
SOURCE:
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
Changing correction ribbon
First this is old school after hitting the correction you must press the letter you are trying to correct. if you knew this and the correction tape is properly installed and lifts up you may have old supplies, If you want to talk yuo can call me.
DickyO
216-269-3918
Dec 05, 2014 | IBM Correcting Selectric Iii Typewriter...
My typewriter will not type the correct letters I have replaced the wheel twice any suggestions?
Make sure that ps pitch is not selected. check if ribbon or corr. tape is in printwheel
Sep 26, 2014 | Brother ML100 Daisy Wheel Electronic...
My Brother ML100 is not printing what I type
Hammer sticking and typing incorrect letters (and or skipping letters): 1) make sure daisy wheel installed correctly. 2) hold down CODE key & Q (RESET) to reset wheel...if still not corrected 3) WD40 the hammer at the base & joints where moving parts are, keep typing until oil seeps in (this last one fixed it for me)
Typing light and inconsistant-top part of letter okay but bottom too light or not there: to left of hammer (at base) are 2 screws, I losened them and adjusted hammer to different forward and backward spots..finally found the ideal location where full letter printed and had the correct force it needed to print correctly.
Feb 21, 2013 | Brother ML-100 Typewriter
Not typing all letters clearly
Try reseating the printwheel. It has to be in correctly and home out (spin) when turned on.
Dec 22, 2012 | Brother Intl. Standard Electronic...
I have a gx6750 correcting typewriter. The problem is, the correcting part of it does not work. I am wondering if the correctable ribbon indicates "correctable" on the cartridge or not. I am...
A correctable ribbon should be correctable. Is the ribbon being lifted up high enough to correct?
Is there any letters on the correction ribbon and is the ribbon installed correctly? Old ribbons lose their tackiness over time, try advancing the ribbon by hand to get to fresher ribbon.
Jul 08, 2011 | Brother Office Equipment & Supplies
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
Correction function not working
Make sure the ribbon is a correctable (yellow or orange core) not a multi strick (blue core)
Sep 13, 2007 | Brother GX-6750 Typewriter
Brother ML100 typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
Brother ML-100 Typewriter Logo
148 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
