Question about Infinity BASSLINK Car Subwoofer
Basslink Stoped working after a month ** sound ** red LED
Iv had a basslink for about a month and it has been working great, but last night i turned the car on and ** sound and the red LED is off. I checked all the connections and there solid. Im usin the rca front inputs and the control wire is spliced with one of the front speakers.
  • Trama Mar 10, 2008
    Fuses are fine, ** nicks in the wires, and the splices are good this, but still ** power
  • 26 Answers
Check all your power fuses and insure you havec power where it is supose to be. maybe you have blown a fuse.
Posted on Mar 10, 2008
Need schematic diagram infinity basslink subwoofer
Design: The BassLink brings together a 10" subwoofer (treated paper cone, foam surround), a 10" passive radiator (to increase efficiency and limit distortion), and an extremely efficient, specially designed 200-watt Class D amplifier that work as an integrated system. Special circuitry monitors voice coil position to maintain linearity at high power levels, so you hear loud, clear bass.
Enclosure Type and Materials: The enclosure is made of an acoustically inert polymer which is rigid enough to resist flexing and dampens any resonance.
Servo-Control: The servo-control system continually monitors the performance of the speaker and ensures that the amplifier delivers exactly the right amount of power.
Class D Amplifier: This unit has a built-in 200 watt Class D amplifier which is highly efficient and designed specifically for use with the subwoofer and passive radiator combination.
Auto Turn-On Feature: When the speaker level inputs are used, the system will automatically turn on and off with the radio. Note: The auto turn-on feature does not operate when the preamp level inputs are used, unless the remote turn-on lead is connected.
Low-Pass Crossover: The low-pass crossover frequency can be varied from 50Hz to 120Hz for a seamless transition between the output of this unit and that of the other speakers in the vehicle. The crossover has a slope of 12dB per octave.
Bass Boost: The amplifier includes a continuously adjustable bass boost from -6 to +3dB centered at 40Hz.
Phase Switch: Allows you to select normal or reverse for best bass.
Mounting: You will be able to put BassLink in a variety of in-vehicle locations, thanks to its compact size and mounting feet that enable the rigid polymer box to be mounted vertically or horizontally.
Vertical Mounting Dimensions:
Width: 14.625"
Height: 13.375" (including feet)
Depth: 8.675" (10.076" including feet)
Horizontal Mounting Dimensions:
Width: 14.625"
Height: 9.5" (including feet)
Depth: 12.75" (15.1875" including feet)
BassLink LC Remote Level Control
Overview: The BassLink LC allows you to adjust the volume of BassLink powered subwoofer.
Installation: The BassLink LC may be mounted under the dash or may be dismantled and mounted inside the dash for a factory appearance.
Under-dash Mounting: Select a mounting location that allows easy, safe access to the control while driving. The BassLink LC has mounting "ears" to use as a template for drilling pilot holes. Attach screws through the "ears" to secure the BassLink LC to the mounting surface.
In-dash Mounting: Disassemble the BassLink LC by removing the Phillips-head screws on the front, rear, and top panels. Remove the bottom and side panels and disengage the RJ11 connector from the back panel. Choose a mounting location that allows easy, safe access to the control, and provides 1-3/4" clearance behind the mounting surface. Drill a 9/32" hole in the mounting surface. Feed the BassLink LC's potentiometer (with the knob removed) through the hold and use the nut provided to hold the control in place.
Connecting to BassLink: Route the cable behind the dash or other interior panels and under the carpet. Do not route the cable outside the vehicle. Connect the cable on both ends.
Inputs and Controls
Inputs:
Universal Interface: Front and rear, left and right Universal interface speaker-level inputs (for use with the supplied speaker-level input wiring harnesses)
Line Level RCA Inputs: Front and rear, left and right female preamp level inputs
+BATT (+12V): Gold-plated screw terminal, 0.350" wide
REM (remote turn-on): Gold-plated screw terminal, 0.350" wide
GND (ground): Gold-plated screw terminal, 0.350" wide
Fuse: There is an installed 20 Amp fuse
Remote Gain Control: Phone type jack for included remote gain control
Controls:
Gain Control: Rotary control that sets gain (variable from 250mV to 4V)
Crossover Control: Rotary control that sets the low-pass crossover point (variable from 50 to 120Hz)
Bass Boost Control: Rotary control that sets bass boost level (variable from -6 to +3dB, centered at 40Hz)
Phase Switch: Selects normal or reverse phase (0 or 180 degrees)
Power LED: The power LED glows red when the BassLink is on
Servo LED: The Servo LED glows green when the servo circuit has determined that the woofer has reached maximum excursion and power to the woofer has been modified to provide maximum performance. The LED should light momentarily during high-level bass transients. Note: Avoid adjustments that cause the LED to remain lit for an extended period of time
Thanks
Apr 01, 2012 | Infinity Bass Link Subwoofer Car Audio...
Basslink has no output, but Power LED and Servo LED always on.
One or more of the DC to DC outputs might be bad. Check the
/- 54v on the main PCB and the /-15v on the switching controller PCB.
Losing one side of the 15v will cause the limit comparator to rail and force the servo protection, even with no input signal.
Apr 02, 2010 | Infinity BASSLINK Car Subwoofer
Is the light on the infinity basslink suppose to be red or green
Hello jmw3031,
The Basslink should have both a red power LED and a green servo LED. The red LED should be on when power is applied. The green servo LED should only come on during high-level bass transients. Turn the gain down slightly if it stays on for extended periods.
Hope this helps.
Jul 15, 2009 | Infinity BASSLINK Car Subwoofer
Basslink red light on but no sound
check the all power lines and regulator .is any of them overheating?
then check the power amp ic or transistors.
nuwan.
Jan 12, 2009 | Infinity BASSLINK Car Subwoofer
2nd Basslink, still no power-on. Please help
this is in response to the post below:
I just bot a basslink t and i wired it up and nothing it just keeps blowing the fues in the unit i got mine on ebay2.gif so i dont know if i can use the warranty dose anybody have an ida for me- britter623
I got a used basslink about a month ago and had the exact same prob kept blowing fuses...found out that the voice coil had blown on the infinity...so I had a brand new dvc polk 10 sittin in the closet, I swapped them out, put the polk in the place of the infinity sub, however, the magnet is much larger, hence, dual voice coil, it would rattle sooo much from the passive radiator against the magnet, also could not turn the gain up at all due to the rattle. I got the bright idea to build a "custom fiberglas enclosure for the polk and incorporate the infinity's parts(amp/control) I finished the box finally last night and hooked it up this morning, no power, no lights, no nothing! s@#%, F&@%! ANyone had a prob w/the amp not having the lights turn on, no power??? Hope that helps about your fuse blowing issue.
Jul 15, 2008 | Infinity BASSLINK Car Subwoofer
Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Mar 19, 2008 | Infinity BASSLINK Car Subwoofer
No Sound from Basslink
Do you have speaker wiring or RCA's hooked up from AMP to Basslink? Also check the settings, make sure you are have bridged the channels on amp.
Feb 02, 2008 | Infinity BASSLINK Car Subwoofer
Power LED lit, Servo LED lit as well, no output
check the power cables on the amp and the inputs.isome time when ground cable disconnect the lioghts will light up any way. depending on the way ur vehicle is ground ed .toyota chssis r usually posite un like the norm which is neg.rating please
Jan 21, 2008 | Infinity BASSLINK Car Subwoofer
No power
Other than the +12V, the ground (-) and the 2 RCA inputs, normally external amps have also a remote trigger which switches it to active on. The remote trigger is activated by a wire from the head unit. Colors would either be yellow or blue but depends on manufacturer of head unit. Alternately, you can connect a simple toggle on/off switch to activate the external amp.
Additionally, pls verify that the 2 RCAs from your head unit are audio out and not audio in for aux source.
Good luck and kind regards.
Nov 01, 2007 | Infinity BASSLINK Car Subwoofer
Light is always on!
yes the problem is in the installation.the power supply usually has 2 to 3 positives one positive which is usually red go directly to battery. the other,either yellow,orange,or blue go to car stereo(not to battery or ignition) this supply,turn off the amp when u turn of the stereo. hope this help u....
May 09, 2007 | Infinity BassLink II Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
460 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Richard Lukszys
Richard Lukszys
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
