Onkyo Amplifier TX-DS777.
Cannot turn on by remote controller. Want to turn on manually
Ok, here is my little spin on remote controls.
Sometimes they can be overloaded with commands and lock up the processor that is inside the unit.
The remote can be saved.
1. Remove the batteries and press every button on the remote control and then install new, not the batteries you took out, but new batteries and see if that works.
2. If step one does not work, then you can remove the batteries and unfold a small paper clip and bend it into a U shape and use it to touch the contacts on both ends of the battery contacts together and clear the memory.
3. Test the remote control, if you have a camcorder or a digital camera, and a cell phone will work. Point the remote at the device and press any button, you should be able to see the IR (Infrared LED) lighting up on the display.
If after all of these procedures are followed and you still do not have command of the device that you need to control. You still have more options.
Either replace the remote control with a new or compatible one, I use 1-800-remotes, www.remotes.com.
Or have the device that you are trying to control diagnosed by a technician and see if the remote IR receiver in the unit has gone bad.
I hope that this helps you with your remote issues and as always, Thank you for using FixYa.
asnowman
If the Standby indicator is ON, press the Standby / On button once for On, once again for Standby
