Question about Reddy Heater-30,000 BTU Propane Forced-Air Heater
Reddy heater 35
I have ** ignition, replaced the spark plug. Still ** luck. I have ** manual with the heater. Is there a fuse somewhere?
  • 625 Answers
No fuse per se, but mounted on the round plate where the burner nozzle is and slightly to the upper right is an overload device with two red or white wires coming out of it. those two wires connect to two stab connectors on the capillary tube. you can try by jumping out those two stabs to see if the heater will fire up. if it does, then go to www dot desatech dot com and purchase a new overload. check for a good ground between the spark plug body and the machine metal part.
Posted on Mar 10, 2008
Reddy heater, 50,000btu, won't ignite, no spark at plug, good fuel spray
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 18, 2011 | Reddy R60A Utility Heater
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Heater won't ignite
Moving mine while it was running fouled the spark plug. You can remove the top of the Reddy Heater and access the plug. In my case took less than 10 minutes and it's up and running again. I removed the top and replaced the spark plug. No problems
Jan 24, 2009 | Reddy Heating & Cooling
Ignition
This is a "probably". The reset button trips because the photocell fails to see a flame in the combustion chamber. That's its job.
Check the ignition device ( transformer, coil). See if 110v going in. If there is no spark coming out, replace it.
Troubleshooting tips
Jan 10, 2009 | Reddy Heater-30-55,000 BTU Variable
Kerosene Reddy Heater, fan comes on, but it won't ignite, it just blows kerosene out the front. There is no electricity getting to the plug. Please reply soon, I need it tomorrow!! Thanks
Your description does not leave much to go on, because you don’t state the model heater that you have. You see, there are 2 different technologies that come into play on portable kerosene heaters. First there is the older version spark plug type heater, and, second there is the newer computerized type with Hot Surface Ignitor (HSI) technology.
Since you state "There is no electricity getting to the plug", the KEYWORD here is PLUG. I am going to assume that you have a spark plug type heater. NOTICE: if your heater has HSI technology- disregard this post because it will not apply.
Causes for "no electricity to the plug":
  1. no electricity to the unit
  2. a defective Safety Control (reset)
  3. a defective photocell
  4. a defective Ignition Control (transformer)
  5. loss of ground to the Ignition Control
I am including a link to some troubleshooting tips for spark plug type heaters. These heaters are relatively simple, but, be careful. Stay away from the fan and take precautions from the obvious shock hazards. Troubleshoot each of the above until you find the problem.
Dec 04, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater 55,000 BTU will not ignite
Ours did that too one year. Seems to me we changed the spark plug, it had spark but too weak I think.
Jan 31, 2008 | Reddy Heater-30-55,000 BTU Variable
Please HELP
www dot desatech dot com is a parts distributor for reddy heat products. on their main page they have a short troubleshooting guide. the motor needs to provide 3.5 psi of air across the fuel nozzle to suck the fuel out of the reservoir. check your ignition source (spark plug, hot surface igniter) if the hot surface igniter is broken get a new one, if the spark plug don't spark, check the gap might be too big. see if the spark plug is grounded. poor grounds will cause intermittent sparking. check the high voltage wire for breaks in the insulation, might be shorting out to ground BEFORE the plug. gap should be 75 thousandths.
Dec 04, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30,000 BTU Propane Forced-Air Heater Logo
430 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
