Question about Canon PIXMA iP3000 InkJet Photo Printer
Printer wont print anything black
Wont even print black on the nozzle check pattern. but ink carttridge is full?
    Genius:
  • 3,587 Answers
Hmmm..even on test page, eh? maybe you need a new set of drivers(they get corruped easily).
Posted on Mar 09, 2008
I have a canon multifunction MX700. Suddenly, my black ink stopped printing. Printer prints in other colors. I have turned the power to both printer and computer on and off, have checked the USB cable,...
Dear Adrienne,First make sure that the black ink is not empty. If you are sure the black ink is full enough you need to check the print head condition. The print head may be clogged or faulty.
To fix the clogged print head,please perform the following step:
  • Print the nozzle check pattern, access the following menu on LCD: Menu>Maintenance>Nozzle Check. The good nozzle pattern should like below sample image.
  • If the print head nozzle missing some color (i.e Black) the perform print head cleaning: Menu>Maintenance>Cleaning. Then print the nozzle check pattern again. Note: you may repeat this step up to 3 times.
  • If the problem still remain,then you should perform Deep Cleaning: Menu>Maintenance>Deep Cleaning.
If you have perform the above steps but the problem still the same,please check whether the black nozzle missing partially or totally. The faulty Purge Unit (ink pump) may cause the same problem. I mean the purge unit does not work properly so the ink cannot flow. Good luck :)
Regards,Xanda
Oct 05, 2011 | Office Equipment & Supplies
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
Black ink jet doesn't print
if your black ink does not print, there is a possibility that the nozzle of your printer are clogged by dried inks, to print a nozzle check. turn off the printer then press and hold the paper (middle) and power buttons together for 3 seconds then release. it should feed the paper and print a nozzle check pattern. if the black lines are full of gaps or breaks in the line. you need to do head cleaning to remove the clogs, press and hold the ink button (teardrop) for 3 seconds, wait until the power (green )light stopped flashing. turn the printer off then print a nozzle check again. just repeat the head cleaning process until the black pattern is ok, as well as the other colors. all shld. be complete.
then print
Feb 11, 2010 | Epson Stylus Photo R200 InkJet Printer
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
Can you help? After changing the cartridges, I keep getting a message about the ink head being incorrect...I am directed to press 'OK' which does not help; then to turn printer off and on again, which...
Cleaning your head might resolve your problem. Perform the below steps to clean the head:
Print Head Cleaning / Head Refreshing If the printed nozzle check pattern is broken, missing, or a specific color is not printed, clean the print head (Cleaning) or print head deep cleaning (Deep Cleaning). Note:
  1. Cleaning the print head consumes a small amount of ink. Cleaning too often reduces the amount of ink in the ink tanks.
  2. Print head cleaning is performed when you connect the power cord. Your machine may perform print head cleaning periodically to avoid clogging.
Overview:
Step1:
Print the Nozzle Check Pattern.
To check whether the print head nozzles are clogged, print the Nozzle Check Pattern.
downicon.gif If the print quality is poor, perform print head cleaning.
Step 2:
Perform print head cleaning.
This unclogs the print head nozzles
Print the Nozzle Check Pattern again.
If the print quality is still poor, perform two print head cleanings.
downicon.gif Print the Nozzle Check Pattern again.
Step 3:
Perform deep print head cleaning.
This is a more powerful cleaning.
Displaying the Maintenance screen
  1. Ensure that the printer is powered on.
  2. Press the <Menu> button.
  3. Press the left or right cursor to select [Maintenance/settings], then press <OK>.
  4. Press the left or right cursor to select [Maintenance], then press <OK>.
Print Nozzle Check Pattern
  1. Press the Open button to open the output tray.
  2. Load letter-sized plain paper in the auto sheet feeder (ASF) or the cassette.
  3. Display the Maintenance screen on the printer.
  4. Press the up or down cursor to select [Nozzle check], then press the <OK>.
  5. Press the up or down cursor to select [Yes], then press <OK>. (The nozzle check pattern is printed.)
  6. Confirm the nozzle check pattern.
05sj00160_03a.gif 05sj00160_03b.gif < 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
  1. When all patterns are printed normally, press the up / down cursor button to select "All A" and press the OK button.
  2. When any patterns are printed abnormally, press the up / down cursor button to select "Also B" and press the OK button.
Print Head Cleaning:
  1. Display the Maintenance screen on the printer.
  2. Press the up or down cursor to select [Cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head cleaning.
    Note:
    Do not do any other operations until print head cleaning is completed.
  4. Print the nozzle check pattern and check the print head status.
Deep (Print Head) cleaning:
  1. Display the Maintenance screen.
  2. Press the up or down cursor to select [Deep cleaning], then press <OK>.
  3. Press the up or down cursor to select [Yes], then press <OK> to start print head deep cleaning.
    Note:
    Do not do any other operations until print head deep cleaning is completed.
    Note:
    If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. (After a given time interval, ink could dissolve itself, resulting in ink unclogging.)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
New ink cartrage
Note:
    Note:
    Note:
    Note:
    Ifthe printed result does not improve even after doing print head deepcleaning, turn off the printer. Then, after 24 hours or later, do printhead deep cleaning again. (After a given time interval, ink coulddissolve itself, resulting in ink unclogging.
Jan 08, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ink cartridge assembly not going to correct posy to replace black
Remove the cartridge and put it back in. If still it doesn't work, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the black pattern or no black appears at all, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Jan 01, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Black ink not printing
You have to run a head cleaning cycle:
Follow these steps to clean the print head:
  1. Make sure the Stylus CX is on and the cp_light_183_er.gif ink light is off.
  2. Hold down the cp_button_48_er.gif ink button for 3 seconds until the cp_light_1.gif On light starts flashing. The Stylus CX runs a head cleaning cycle and the cp_light_1.gif On light flashes.
    alert_caution.gif Caution: Never turn off the Stylus CX while head cleaning is in progress. You may damage it.
  3. When the cp_light_1.gif On light stops flashing, turn off the Stylus CX.
  4. Load letter-size paper in the sheet feeder.
  5. Press the cp_button_48_er.gif ink and cp_button_1.gif On buttons together and hold them down for about 3 seconds. The Stylus CX turns on and prints a test pattern, which includes a nozzle check. Shown below are some examples of what the nozzle check may look like:
    Nozzle check pattern with no gaps im_158_er.gif Nozzle check pattern with gaps im_159_er.gif
  6. Examine the nozzle check. If it does not look like the nozzle check pattern with no gaps as shown above, repeat steps 2 through 6.
alert_note.gif Note: If you don't see any improvement after cleaning the print head three times, turn off the Stylus CX and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
If you do not use your Stylus CX often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Oct 24, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Poor colour
3. Use the [<] or [>] cursor button to select 'Maintenance/settings', then press the <OK> button.
4. Use the [<] or [>] cursor button to select 'Maintenance', then press the <OK> button.
How to print a nozzle check pattern
1. Extend the paper output tray. (Confirm that the paper thickness lever is set to the left.)
2. Load a sheet of A4 or Letter-sized plain paper in the auto sheet feeder.
3. Display the MAINTENANCE screen. (See How to display MAINTENANCE above.)
4. Use the <up / down > cursor button to select NOZZLE CHECK and press the <OK> button.
5. Use the <up / down> cursor button to select Yes, then press the <OK> button. The nozzle check pattern is printed.
White lines are present ,black and/or color inks are not present.
- When all patterns are printed normally, press the <up / down> cursor button to select 'All A' and press the <OK> button.
- When any patterns are printed abnormally, press the <up / down> cursor button to select 'Also B' and press the <OK> button.
Top of Page
How to do print head cleaning
Note: Cleaning the print head consumes a certain amount of ink.
1. Display theMAINTENANCE screen. (See How to display MAINTENANCE above.)
2. Use the <up / down > cursor button to select CLEANING and press the <OK> button.
3.Use the <up / down> cursor button to select 'Yes', then press the OK button to start print head cleaning.
Note: Do not do any other operations until cleaning is completed.
4. Print the nozzle check pattern and check the print head status. (See How to print a nozzle check pattern above.)
Top of Page
How to do print head deep cleaning
Note: Print head deep cleaning consumes more ink than print head cleaning.
Perform this procedure only when print head cleaning cannot resolve the print problem.
1. Display the MAINTENANCE screen. (See How to display MAINTENANCE above.)
2. Use the <up / down> cursor button to select DEEP CLEANING and press the <OK> button.
3. Use the <up / down> cursor button to select 'Yes', then press the <OK> button to start print head deep cleaning.
Note: Do not do any other operations until deep cleaning is completed.
Note: If the printed result does not improve even after doing print head deep cleaning, turn off the printer. Then, after 24 hours or later, do print head deep cleaning again. After a given time interval, ink could dissolve itself, resulting in ink unclogging.
When the printed result does not improve even after these steps, replacement of ink cartridges may be required.
Nov 14, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
71 people viewed this question
old marine
old marine
