Question about Mag Innovision LT982s 19" Flat Panel LCD Monitor
Mag Innovision LT982s screen problem
When the screen is turned on, there is a dim screen picture for a split second before it goes black. The power light is still on the the screen is blank. What could be causing this?
    Brigadier General:
  • 6,966 Answers
Based on your post/description, I will initially suspect the inverter and/or the CCF Lamps since as you posted "dim screen picture" indicating that there is ** backlight(s) and/or it is **t receiving power from the inverter.
If the unit is relatively new and under warranty, it may be to your advantage to have it replaced or seek the services of their Service Center. Should you want to do a DIY, it would be required that you be familiar with electronic circuitry and components, use of a DVM and a soldering iron and access to a service manual or at least a schematic diagram.
Incidentally, there are k**wn cases where similar issues could be resolved if you try lowering your display properties (resolution and refresh rates) but that would also include the powerlight changing colors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 10, 2008
Sound no picture
inverter board issue.
Feb 22, 2017 | LG Televison & Video
How to fix black screen on television?
Inverter board is responsible for the backlighting.
Oct 28, 2015 | LG Televison & Video
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Screen flashes only for a split-second (as a second display for an iMac)
The inverter is faulty.If your Monitor is powered by a mains'kettle' type lead,then it MAY be repairable,provided you can find someone to do it.If you have an external power supply,then the chances are you have a separate inverter,and it is doubtful whetther you can find the fault or a replacement circuit board....which is why we have become a throw away nation !!
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
No picture on my x5g-komodo7 monitor
A reddish picture is the classic symptom of worn out backlight bulbs.
Sensor circuits usually shut down the power to the bulbs in a second or so.
Monitor Mike.
Jan 03, 2009 | Sceptre X5g-Komodo VII 15'' LCD Monitor
A17w221 goes off automatically with power on
I have the same problem. The next stage is that the picture won't come on at all and the blue light will constantly blink. I think the light source is bad. Noit sure though.
Mar 25, 2008 | Envision A17W221 Television
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Display works - but only for a plit second...
Lower your resolution on your computer. Usually when that happens the resolution is set higher than what the monitor can support. Lower the resolution and try again.
Jul 25, 2007 | Dell E173FP 17" LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Mag Innovision LT982s 19" Flat Panel LCD Monitor Logo
138 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
