Hi, I have a WD elements desktop external hard drive and it is showing on my computer under drivers and printers, but I can't access any files off it and I can't see it under my computer. What can I do?
If this is a new drive, you likely just need to format it. http://support.microsoft.com/kb/313348 There is a link to the Microsoft page on formatting in XP. If you have a different version of windows, just search google for format hard drive.
Disassemble the case, and remove the 400GB disk-drive.
Connect the disk-drive as a "slave" disk-drive to some desktop computer, and see if you can still access the files.
Get the serial-number from the label on the top of the disk-drive, and access Western Digital's web-site, to check if the device is still under warranty. If it is, W.D. will replace it, at minimal cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program -- you can buy another external disk-drive from W.D.'s web-site, at a significant discount.
Any external storage device has three major parts:
* USB cable
* disk-drive
* USB-to-disk-drive adapter
Try a different USB cable.
Disconnect the disk-drive from that adapter, and connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if you can read the files, which implies that the adapter is the part that has failed.
If you cannot read from the disk-drive, check its WARRANTY status. W.D. will replace it, if the warranty is still valid.
Otherwise, W.D. has a "Customer Loyalty" program: find the serial-number of your unit, access their web-site, and purchase another W.D. external storage unit, at a significant discount, by citing the serial-number.
Or, if the adapter is OK, then replace the disk-drive by a new one, and close-up the casing, to create a "revived" external storage device for your use.
hi there could be a couple of things you can try, you could, ( if you have xp ) have the drive in, then go to my computer, then tools, then folder options, click, view, then look down the list for show hidden files and folders, that's one, the other is to take the drive caddy apart, remove the hard drive ( as they are just normal hdd's in external boxes ) connect it up to a spare port on your desktop computer and see if you can transfer files that way, ( note! this will void the warranty on the drive case if you do this if it is still under warranty ) the other way would be to get a data recovery program, like winundelete, which you should be able to find on either your computer or the net for free, hope this will help
Take it back to where you bought it, and get a replacement,
or at least get them to demonstrate that it _does_ work, when connected to a Mac computer (not a Windows computer).
