Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
Magnavox 20MC4304 connection to receiver
I am trying to connect my combo tv/vcr/dvd to a receiver for surround sound but nothing works! I bought a coaxial cable to connect to rear of tv and receiver but it seems to do nothing. I have a sonyHTDDW790 system. The only way I have been able to get sound through my receiver from tv is by connecting through the headphone jack on tv into audio jack in receiver. And still only two speakers produce sound. Is there are way to disable the sound on my tv so I can get it to my receiver? It seems as though the tv is "overwriting" my receiver.
I lost my manuals can someone put it online!
Posted on Oct 12, 2008
    Sergeant:
  • 395 Answers
Your set has a coaxal DIGITAL output so you must have a coaxal digital input to your reciever and that input must be assighned in the reciever to the selected input. page 10 of your manual explains how to hook up to the tv. your receiver's manual will tell you how to assighn the coax input.
Posted on Mar 15, 2008
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
I am having trouble connecting dvr to dvdvcr to older tv
This can get tricky sometimes. It depends if you're connected the DVR to the tv via RCA cables or coaxial cables. For coaxial, connect from the TV's in to the DVD/VCR combo out. Coaxial from your DVD/VCR in to your DVR out. set your VCR/DVD to channel 3/4 depending on your manufacture as well as your tv. If this doesn't work, usually your tv provider may be able to help you out.
Mar 01, 2011 | Televison & Video
Connecting TV to combo DVD and VCR
When you say "can't get the TV to play through the VCR", do you mean that you can't get the cable-stations to play through the VCR to the TV? I'll assume that's what you're trying to accomplish.
The most common way to connect a VCR to a TV is through a coaxial cable, from the port on the rear of the VCR labeled "Out to TV." There should be another coaxial port labeled "Cable/Ant In." This is where I picture your cable programming is currently connected.
Instead, it sounds like you connected the VCR to a modulator (probably thru RCA composite cables, which have yellow / red / white plugs). Then the modulator connects to the TV thru a coaxial cable. This will successfully play the VCR to whatever specific channel (perhaps 2, 3 or4), but the modulator doesn't know of any other signals to send to your TV.
2 possible solutions:
1) If the modulator has a coaxial port labeled "Cable/Ant In" or something indicating "In" at a threaded coaxial port, connect your cable-programming to this instead of the to the VCR.
Depending on what type of modulator it is, when you want to switch from watching the VCR to watching cable-programming, you might have to push a button on the modulator to make the swtich, or you might not. Your modulator might put the VCR on channel 3, and allow the higher cable channels to filter though to their respective stations. Most cable providers will leave channels 2, 3 and 4 blank for this purpose. Try it and see.
2) Axe the modulator. Take it out of the system entirely. Connect your cable programming to the VCR "Cable/Ant In" and use another coaxial cable to go from the VCR's "Out to TV" port to the TV. When you want to switch from watching the VCR to watching cable, press a button on your VCR or the VCR's remote. Usually this button is labled, "TV/VCR."
If this does not help, write back and explain in more detail how your system is currently connected.
--axoplasm
Nov 02, 2008 | Televison & Video
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Sep 07, 2008 | Sony STR-D665 Receiver
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Only works when playing a DVD.
This is an easy and quick fix.
What you will need:
RCA cables (audio)
( possibly Line out converter )
Your television is either going to need Video Out, or if you have a VCR or VCR/DVD combo connected to your television. Assuming that you have a VCR combo, the way your tv should be set up is on the back of the vcr combo, your cable will run into the coaxial IN and then you have another cable running from Coaxial OUT to your tv. If you have it set up like this, then the DVD / VCR combo will have RCA Audio / video out ports on the back side. Run RCA cables from the DVD / VCR output to the surround sound INPUT. If you already have your inputs in use on the surround sound, Radioshack has RCA splitters for about $1.50 each, you might need to pick some of them up so you dont have to go through the trouble of reaching behind it all the time to disconnect and reconnect whatever your trying to connect. Now if you dont have the DVD / VCR combo, then your TV "MUST" have RCA Outputs. if it doesnt, then the only way that your going to have your surround sound connected to your tv is to take the TV apart and get a RCA "Line output converter" and wire it to the left / right channels of your tv. From what I've read, i think this is what your trying to do so I hope this helps
Feb 19, 2008 | Durabrand STS92 System
I want to connect my sound system to my tv
Jan 20, 2008 | Durabrand STS92 System
Connecting receiver/dvd and vcr combo and TV
do u have rca outs form the tv to the aux in of any dvd system sterio unit
Jan 10, 2008 | Sony DAV-FC8 System
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
