I plugged in y hd set precision gaming headset an **thing happssay is installd but ** sound how do i fix it .i can even ecord my sound se if it works and it tells me it a ati hd something s i dunn. maybe u can follw me somesep of what to do
Honestly no manual is even needed and I don't believe they are even readily available on this old of a game controller. If you have a specific question or trouble I am sure I could help you. The device should just be plug and play. Although you will have to set up the games individually to use it. Thank you, Lee
one of 2 things is going on either you have to cheap a headset/mic or your need to mess with the mic boost and other mic settings to get it just right.
Sounds like there are some settings within the Conan game itself that need to be adjusted to output to a headset, but I have never even HEARD of this game, much less played it, so don't quote me. Just trying to help.
yes there should be a little speaker like icon in the task bar also known as the start bar or menu double click on it.. the there should be a drop down menu that says options.. click it then click properties go through the scroll down menu and make sure that microphone is checked.. then click ok or apply. then adjust your volume for the mic
Friend there are two possible solutions that i can suggest:
1) Maybe you don't have an updated antivirus on your computers
so a part of your driver maybe corrupted.
A possible solution is to install an updated antivirus program if you do not not have any or update it to your antivirus company's web site if you have already. After doing this reinstall your driver for your sound card. Then there you go.
2) Maybe you are not using a sound card (it is recommended that you use a soundcard to have the best sound). If you do not have one you'll need to buy one. After doing this repeat my solution number 1).
Thanks i hope i have solved your problem.
P.S. please rate me if it helped you!
Make sure that the recording software is installed.
Goto start -> control panel -> Sound and audio devices
now if you look towards the top, you'll see 5 tabs. We'll be paying attention to "Audio" and "Voice". Both of them should have a "default device" listed in there, if it's greyed out, then it's not working.
If you have a Dell, you should have a CD that has all the device drivers located on it. If you don't, you can call dell to have them send you one, or you can look manually on their website for each driver according to the computer type.
i really need help i lkthe way these head fones fit but not workin
