** pictue, ** sound. Blue screen with Vidio 1,2 & 3
  • 4 more comments
  • ginniec Mar 09, 2008
    There is ** picture or sound. Only color blue is on the screen when vidio 1,2 and 3 appear in the right upper corner. Other chanels show a blank black screen. Volume up and down does **t show those small virtical bars.
    Make is Sanyo EDTV, LCD TV Monitor, Model is CLT 2054
    10 minutes will be up at 7:01 p.m. I did a reset "again" and turned the set off. I've reset it several times and eventually turned the set off. ** change when it was on again. **, it's **t under warranty. Just tried again ** lucK. When I press up/down vol. it turns arrows red. Don't k**w if that means anything
    It's a small 20"creen set which I could caru into a service center. Do you know how much a control system board costs is it worth fixing?
    Does your comment mean that the cost to fix this TV would be as much as the cost to buy a new unit?
  • ginniec Mar 10, 2008
    Right. Your previous answer was unclear! Guess it's onto the internet to check out prices.
    Genius:
  • 3,587 Answers
Wow..what kind of projection tv you working with there?
Posted on Mar 09, 2008
  • 6 more comments
  • Patrick Michaels
    Patrick Michaels Mar 09, 2008
    thanks..but still need the model and make of the unit to proceed..
  • Patrick Michaels
    turn it off for around 10 minutes, and see if that helps at all..it's a reset requirement...
  • Patrick Michaels
    let me know when the 10 minutes are up, and we'll see what's next..this under warranty by chance?
  • Patrick Michaels
    it means that your control system board is really and truly unhappy, with a few major issues. i suggest that you call a qualified service person in your location.
  • Patrick Michaels
    well..is it worth more than what you'd pay for an equivalent? not likely...the big issue is to recycle it properly, through a local effort, so it won't become land fill fodder.
    thanks for using fixya
  • Patrick Michaels
    most likley..the parts and labor run around 200 to 400, depending on how many and how long, and how much..seems a 20 inch tv can't be much more than that, right?
  • Patrick Michaels
    Patrick Michaels Mar 10, 2008
    happens some time..usually I'm quite blunt..
  • Patrick Michaels
    thx for using fixya..
Problem with audio and vidio
Is this a problem only with the cable box or also with oother sources as well?
Feb 03, 2008 | Pioneer PDP-6100HD 61 in. Plasma...
I transfered from watching my sattelite tv to watching a dvd using the tv control. The dvd sound worked ok, but I couldn't get a pictue. Then I tried to watch tv again, but the vidio would not come in,...
Just in case, here's the 108-page user's manual for your TV:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
Yor "NetCommand" TV remote is a wondrous thing, capable of throwing off anyone.
When the 'Device Selection Menu" is dispayed, and only when the device icon is highlighted,
does the key work, and it also only works when the remote is in "A/V Receiver" mode -
not in "CABLE or DBS" mode, nor "VCR" mode, nor "DVD" mode.
So, (1) set the NetCommand remote to "A/V Receiver" mode
(2) bring up the Device Selection Menu, using the key on the remote
(3) highlight the Satellite receiver input icon (highlighted with a Yellow outline)
(4) press GUIDE on the remote, to swap the analog digital setting.
Also displays ChannelView for Antenna 1 and Antenna 2 - you may have accidentally
set the TV to get its input from the wrong Antenna.
If your TV has lost memory of its DBS source, you may have to re-teach the TV (using the remote)
that the DBS (Digital Broadcast Satellite) input exists, and to which input its connected.
Refer to "Edit NetCommand, Add an A/V Receiver", pages 39-45 of your Owner's Manual.
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have sound but no pictue when playing dvd. No blue screen.
install a video codecs packet for example use this k-lite
Aug 08, 2010 | Zenith ZPA-314 Portable DVD Player
My 27" ( aprx 6 yrs old)Tv first had only a horizontal line across the screen about 1/2" wide, good sound but no picture, now it only clicks like its turning on and off when you plug the tv in, no pictue...
It has gone into a self protect mode where it will shut down because you have a fault in the frame stage of the TV (horizontal line). This will most likely be a failure of the frame output IC. Replace this & you should restore the normal picture.
Oct 11, 2009 | Sylvania Televison & Video
No red pigment on Screen
Pull back to TV turn on watch to see if all 3 tubes are lighting up if Red is lighting but no red CK projection Fuild in Tube, look down into lenses if you cannot see pictue clearly then Fuild is Bad.
Sep 21, 2009 | Panasonic Televison & Video
Model KDFE55A20 plays for 1 min. cuts off for 30 sec. on and on
I solved my problem with my sony projection T V join our elite plan and i'll tell you how.
Sep 13, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
Blue halo on bottom 1/3 - Convergence issue with my 43HX70
HELLO SOUND LIKE YOU NEED TO CHANGE YOU IC CHIP'S ON THE CONVERGENCE BOARD.1!1 THERE WILL BE THREE OF THEM .!!! CHANGE ALL OF THEM AND THIS SHOULD FIX YOUR SET. "GOOD LUCK"
Aug 13, 2008 | Toshiba 43HX70 43" Rear Projection...
Lg tv and parcific vidio
YES, DOES YOU PACIFIC VIDEO HAVE COMPONENT , COMPOSITE OR HDMI OUTPUTS ON THE BACK ? THE HDMI HAS BOTH AUDIO AND VIDEO SIGNALS AND IS THE BEST QUALITY PICTURE. BUY THE CABL AT RADIO SHACK, WALMART ETC.
COMPOSITE IS THE YELLOW RCA CONNECTOR FOR VIDEO AND RED AND WHITE RCA CONNECTORS FOR LEFT AND RIGHT AUDIO.COMPONENT IS THE RED, BLUE AND GREEN RCA CONECTORS AND RED AND WHITE FOR AUDIO L & R.
Nov 24, 2006 | LG TU-60PY2DR 60 in. TV/DVR Combo
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
