This problem should be removed because:
Problem with Keurig Platinum B70 Coffee Maker
how much water to vinager to de-scale
Solutions (1)
48 oz. of White Destilled Vinager. Not deluted with water just straight brew until resevior tank is empty. let sit for 4 hours. Fill resevior tank with water and brew until vinerger smell and taste is gone
Suggested Solution (1)
THE VALVE LETTING WATER THROUGH TO THE COFFEE PART OF THE MACHINE IS CLOGGED BUY SOME WHIT VINEGAR AND LET IT SOAK FOR A WHILE AND THEN TRY TO BREW AGAIN, YOU SHOULD GET A SMALL AMOUNT AT FIRST SO KEEP RUNNING THE VINEGAR THROUGH TILL IT CLEARS. HIGHLY RECOMMEND FLUSHING OUT WITH CLEAN WATER WHEN DONE SEVERAL TIMES OR ELSE YOU COFFEE WILLTASTE LIKE PICKLES
kitchenaid coffee maker giving me
kitchenaid coffee maker giving me error 2
err nessage 2
coffee makerdoes not work. err2 message displays. Not able to correct the problem
Error Message
Kitchen Aide coffee maker will not brew. Error 2 shows in clock window.
what does de scale mean? I have cleaned the big
what does de scale mean? I have cleaned the big water holder & use the reusable filter?
Add Your Solution
I descaled my Keurig B-70 and now the coffee is...
I like intense strong coffee. So, I usually brew on the smallest cup setting and use two K-cups. However, I just...
we just bought a keurig from the states and...
it worked fine when we tested it in the states before we packed it into a box to bring home. When we unpacked it after...
Why is the prime light on?
prime light on keurig b70 stays on and the blue lights are flashing under the water tank
prime light on
prime light on display of my b70 keurig and the lights are flashing under the water tank.
Related Topics
Fix-O-Meter
159
159 people viewed this problem
- 0 people are following this problem. Be the first!
Top Keurig Coffee and Espresso Maker Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
