Question about Dryers
Kenmore heavy duty dryer
I have a kenmore heavy duty dryer. Here is the model number; 86015110 60151. It's an older dryer. It recently stopped spinning, or tumbling or whatever it's called, and won't dry my clothes anymore. I really need to fix it and can't afford to buy a new dryer.
Thanks, Tim
  • 131 Answers
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Posted on Mar 10, 2008
Kenmore heavy duty plus dryer modle number 886573130 works fine just stopped heating up.
Gas dryer no heat means the heating element broke or fell apart, need to install new one, go to sears hardware and order a repacement....model # in hand.
Feb 22, 2015 | Kenmore Dryers
My malleys heavy duty 1050 wont tumble.
I could not find much info on your dryer, but there is probably a belt that goes from the motor and wraps around the drum. If the drum is not rotating, the belt may be broken.
May 26, 2014 | Whirlpool Dryers
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore quiet pak 1 heavy duty king size front loading dryer is not heating up, but is tumbling fine. Desperately seeking manual.
Go to and enter the model. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Kenmore video showing disassembly.
Nov 24, 2017 | Washing Machines
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Dryer wont start.
can you hear the motor or does the unit humm or vibrate when it is turned on
if yes then have a look at the belt
if not it's time sor a service call
Aug 04, 2009 | Kenmore 700 6972 Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Where to reconnect yellow-red wire on series 90 heavy duty
At about the 4 oclock position look had for a male spade clip mounted between the inner and outer front panel. Look inside the panel and you will see the metal stripes below the filter that collect the wetness data from the clothing as it tumbles past. Great question! Post your model number to any of these fine forums for
a simple answer that will save you lots of money:
Feb 18, 2009 | Kenmore 62602 Electric Dryer
Kenmore heavy duty 2 way tumble washing machine
You may have a broken inner tub spider. Check for play between the inner drum and the outer tub by moving the inner drum up and down.
If there is excessive play, the spider is broken causing an unbalanced load and therefore no high speed spin can be achieved.
In this case the inner drum would need to be replaced, which means taking the machine almost completely apart. A good tech can do it in about 1.5 hours.
Jan 16, 2009 | Kenmore 44102 Front Load Washer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
377 people viewed this question
Top Dryers Experts
