Question about Garmin GPSMAP 276C GPS Receiver
Garmin GPsmap276c won't go to any screens or shut off
When I turn it on it won't go to any other screens and won't turn off without removing the power supply. ** buttons work it just stays on the first screen that shows some clouds and the product name below
  • 5 more comments
  • qsxc Mar 31, 2008
    I have the same problem, if there any one has a solution?
  • Mark Caliban May 06, 2008
    My GPS will not boot up past the welcome screen. It will not turn off unless the battery is removed. I had some problems last season with the boot up but they cleared up when I made sure the boat power source was turned off before plugging the unit in. This unit worked perfectly when I shut it down at the end of the 07 boating season. I have a new battery on order and am hoping this will solve the problem.
    My GPS will not boot up past the welcome screen. The unit cannot be turned off unless the battery is removed. This unit had some problems with bootup last season but they were resolved by making sure the remote power source was off before plugging GPS in. This unit worked perfectly when put away for storage at the end of the 07 boating season. I realize I should have removed the battery for storage but it was over looked.
  • Anonymous May 08, 2008
    GPS won't boot up past the welcome screen. Unit will not turn off unless battery is removed
  • oulouis Jun 16, 2008
    276C will not power on passed the welcome screen on dim. If I remove the battery and put it back, then it powers on. Only then can I connect it the the charger (external power supply) or to a USB port on the PC.
  • tore116 Jul 31, 2008
    Yes - I have the same problem. After problem arised I updated to unit sw 5.30 but the problem remain the same. To be able to update the SW I had to hold down and . Otherwise the unit was not connected to my PC (over USB).
  • Anonymous Feb 15, 2009
    i have this same problem.
I have the same problem. I tried powering it holding down <power> and <arrow up, it helped to the pc to find the garmin by the usb, i was able to run the latest softaware the 5.50 but the problem still remains, what else can i do to solve this problem
Posted on Mar 08, 2010
Hold the enter key while powering on, reloads software
Posted on Apr 08, 2009
Garmin 276c crashes
Installing and running the Garmin WebUpdater to load or reload the latest update will resolve most issues.
download the latest version of WebUpdater software
You may also want to contact Garmin support for assistance.
1-800-800-1020
Nov 05, 2011 | Garmin GPSMAP 276C GPS Receiver
We have A Garmin 1300. It works fine for a while then the screen goes blank. We hold down the on button for a LONG while then the screen will come back up and make you go through several screens, but...
Be sure to update the firmware by running the Garmin WebUpdater.
Download and Install WebUpdater.
It is not necessary to unplug the vehicle power cable as the unit will shut down automatically if the vehicle power source is not supplying power after the vehicle is turned off. If the vehicle power cable does continue to supply power, then a manual shut down can be done with the power switch on the nuvi but it is still not necessary to disconnect the vehicle power cable.
Aug 12, 2011 | Garmin nuvi 1300 Car GPS Receiver
My garmin 255w nuvi keep turning off and wont turn on
It is a good idea to perform a hard reset on your Garmin Nuvi after updating the software.
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?"prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
Garmin 178C Boots up then shuts off
I've had a similar situation with a Magellan, it would power off despite being plugged in.
Its usually a battery issue, perhaps its not getting enough power? You could try to unplug it and do a "hard battery reset" depending on the type of battery. Keep turning it on and let it run out, until it wont even turn on anymore, after that plug it into a charger while off and allow it to charge completely. Turn it on, see if it still shuts off.
May 26, 2009 | Garmin GPSMAP 178C GPS Receiver
Screen goes blank after locating sattilites.
Accordingto Garmin, this problem can be fixed by disabling the WAAS feature in teh set up menu. There is an incompatibility between the old Garmin software and latest WAAS upgrades. Later software from Garmin is supposed to fix this problem.
May 21, 2009 | Garmin eTrex Legend GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi does turn on when connected to power in car
Hi
I had the same problem. My Nuvi 350 did not power up for a couple of days. I suspected moisture to be the culprit. So I took my wife's hair dryer and blew hot air(in the intermediate setting) into the SD card slot in the GPS for a couple of minutes. Take care not to overheat the GPS or Screen.
Pronto my GPS powered up without any issues.
Hope this helps
Oct 24, 2008 | Garmin Nuvi 660 GPS Receiver
Check the pins at the connector on the back of your unit. Make sure one of them is not bent or broken off. One of the pins on mine is missing about 1/16" of the tip. My boat repair shop says it's the power lead, but Garmin wants $200 for a generic repair.
Oct 18, 2008 | Garmin GPSMAP 178C GPS Receiver
WILL NOT CHARGE SAID BATTERY LOW AND WILL NOT CHARGE
I used another charger in house and charged battery must be the car charger adapter I haven't used it yet but I will today and let you know if it works
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin GPSMAP 276C GPS Receiver Logo
436 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
