Question about Alpine CDA-9856 CD Player
Alpine CDA-9856 I have ** sound when trying to use XM radio. I do have sound with the CD and AM/FM
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Do you have to run in AUX to get XM Radio? Your receiver and unit sound like its ok. This could be a problem with your provider. Contact your provider and their tech dept can help you organise a solution. Is your radio, XM ready?
Posted on Mar 10, 2008
My 2008 honda accord xm radio stopped working.
If it is a built in system, which is sounds like it is. Your XM receiver is not functioning correctly. I believe a replacement XM receiver is covered under your warranty if you have one with your Honda dealership.
Oct 20, 2012 | 2008 Honda Accord
Premium Bose XM/AM/FM/CD/Radio in 2004 GMC Envoy XUV has no sound. First the AM/FM quit working like the unit did not see an antenna. I had the body control module re-flashed which fixed my speedometer,...
You should be seeing BCM trouble codes (DTCs) for the radio with a code reader. I am assuming you are hearing something (noise) from the speakers with the radio on. If so, you may have lost the programming in the radio - you could try re-flashing it. However, that radio has a number of memory locations that are set whenever the radio is turned on - one or more memory modules in the radio may now be faulty.
Nov 30, 2017 | GMC Envoy Cars & Trucks
XM Radio in 2008 Hyundai Sonata sounds bad
Same problem here. I repeatedly complained to XM but got no reply. I listen to XM in 2009 Sonata and it was just as bad.
XM is better than AM. Much worse than FM.
Oct 14, 2009 | 2008 Hyundai Sonata
The factory xm volume to low in 2006 corvette
Separate 'plug and play' XM radios, like the one pictured above, have a "MENU" setup, and you can adjust the "Audio Level" in that menu setting. See if you can access an XM menu. You can also ask your question over at XM411.com or XMfan.com; both are 'fan' websites.
Good luck - nice car too!
Aug 05, 2009 | Delphi SKYFi2 SA10126 XM Radio Receiver
XM radio goes in and out
Call the XM service number, they will refresh your signals. If it was the head unit, the same problem would occur during AM/FM signal transmission
Nov 11, 2008 | 2004 Acura TL
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Panasonic CQ-DF903U How do I hook up my Sirius Radio to it?
Sirius radio connects via a special dock. Sorry, but you're screwed with your XM unit...
Apr 05, 2008 | Panasonic CQ-DF903U CD Player
XM reciever FM transmitter problem
hi Mr.Frazier....is the xm radio hardwired installed? if it's a yes you have to go to a professional(bestbuy, retailers) to have the connection check.. the problem is not within the xm radio..it's on how it was installed or set up...
If the radio was not built..well, that's much better we just have to check the audio connection from you're xm to fm radio (make sure to check if what band it is connected..such as AUX,CD etc.) if there's a sound but you're only getting preview channels..refresh must be send on the radio...you can call xm to ask for that OR do it online at www.refresh.xmradio.com and type in your 8 digit radio I.D just have to follow the activation instruction faithfully...Godbless!
Aug 26, 2006 | Delphi Roady2 SA10085 XM Radio Receiver...
Alpine CDA-9856 CD Player Logo
113 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
