Question about Car Audio & Video
Kenwood amplifire kac-7201,800 watt
When turn the ignition imp comes on then goes back off,it wond keep the power on, there is a fan on top of imp which stays on when ignition is turnd on?please help.thanks
  • NewUnit16 Sep 17, 2008
    same as above. it happens to my amp as well.
All sorted.thankyou
Posted on Mar 11, 2008
Overheating
do a full system flush on the radiator and engine and the lines to the heater. flush them out. also change the thermostat and the temp switch, the temp switch sensor is the one with only one wire on it with either a 11mm or 13mm head on it depending what one was fitted. after it is flushed reconnect the pipes add the water and antifreeze, when all clean in the system the water should come out clean. 50/50 water antifreeze should be used. leave the top off the header tank and run the engine with the heater on number one. keep squashing the pipes as the engine warms up to help get the air out and keep the header tank full to the top. when the fan kicks in to cool the rad turn off the engine and leave to cool down when cool top up to the line and put the cap back on. wile you are doing the bleeding you should see the temp go up. if the heat goes to or above a 100 and the fan does not come on then the fan switch or motor may need changing, thermostats last for around 5 years, temp switches can last up to 5 years temp switch for the fan can be around 3 to 8 years.
Mar 07, 2014 | 1992 Subaru Legacy
My 2001 Chevy Impala is overheating, I put water in the radiator and it helped at first, but now it's staying on overheated all the way on the temp thermometer, I put anti freeze and it's still doing it....
First thing I would do is to remove the thermostat and see how it performs.
The thermostat may not be opening and short circuiting the cooling system
Sep 09, 2017 | Cars & Trucks
Power steering pump on my 2001 mini one stays on when the ignithion is turned off
It is not your ps pump that is staying on, it is the ps pump COOLING FAN located below the pump. On 2001-05 Minis, this fan is wired directly into the wiring of the main radiator cooling fan, which has two speeds, low and high. When the engine compartment temperature reaches a certain level, the main radiator fan is supposed to come on, and since the ps cooling fan is also wired into that, it is supposed to also come on. But, that low fan speed is achieved by routing power to a resistor, located at the top back of the radiator on passenger side, that cuts the power down. This resistor is highly prone to corrosion and failure. When that happens, neither the main radiator cooling fan nor the ps pump cooling fan can come on UNTIL the engine compartment temperature reaches an alarming level, which switches through a relay power directly to the fans, by-passing the resistor. By then both fans are attempting to bring the temperature back down to a safe level. Then, if you turn your engine off before the temperature reaches the lower threshold so that the fans are still running, the ps pump cooling fan will just keep right on running, as there will be no relay signal given to turn it off, and your battery will be drained.
To fix this, the resistor either needs to be replaced, or, the resistor can simply be removed and the contacts jumped. This last fix will mean that when the lower temperature threshold is reached, the main radiator cooling fan will come on at full speed, and the ps pump cooling fan will also come on. After my ps pump failed due to fan failure, I did this to my '03 Mini, and have run it for years this way. No more ps pump problems. You do need to make sure you keep the fan clear of debris and freely turning, or you could have bigger problems, like a fire, since the wires will get very hot sending power to the fan motor when the fan is bound up with the motor not turning. A blown fuse will often be the first indication of a fan bound up.
Apr 14, 2012 | BMW Mini Cars & Trucks
When my unit is turned off the furnace blower fan keeps running what is the problem
this sounds like the automatic fan control is staying on it comes on at temp rise and goes off on temp fall , the fan control could be dirty at the back of it might just need a clean .
May 18, 2011 | Coleman Heating & Cooling
On a 2006 pt cruiser fan wont come on when ac is turnd on.wont stay cold for long
could be a number of things, could be your system is plugged, your compressor is weak, your relay for your fan needs to be replaced or your fan needs to be replaced
Mar 05, 2011 | 2006 Chrysler PT Cruiser
Furnace goes on red light stays on exhaust fan for heat chamber goes on gas igniter comes on but soon as gas comes on furnace kicks off have to shut off power for furnace for it to reycyckle but same...
Check your filter to make sure it is not plugged. If it is plugged - replace with filter recommended for your furnace. Every manufacture recommends you have your furnace checked and cleaned on an anual basis to keep itrunning safely and at it's top efficiency. If the filter is plugged or the blower wheel plugged, the furnace will shut itself off. Make sure all registers are uncovered - suppply and return registers.
Jan 03, 2011 | Heating & Cooling
My 1800 watt kenwood keeps goin into protect mode as soon as i turn it on.. why?
disconnect load (speakers), check if it still goes in to protection if so then your output stage might be faulty
Apr 17, 2010 | Kenwood KAC-9152D Car Audio Amplifier
I dont no how many watt my amp has
Hi and welcome to FixYa,
To my understanding, a Kenwood KAC-628 is rated with max power of 100 watts X 2 at 4 ohms per channel. Incidentally, it is bridgeable resulting to 300watts X 1.
Good luck and thank you for asking FixYa.
Dec 23, 2009 | Kenwood Car Audio & Video
Car Audio & Video Logo
97 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
