Philips 30PF9975 30 in. HDTV LCD Television
Problem for Philips 30PF9975 30 in. HDTV LCD Television
Connection problems
By Forzammer on Mar 09, 2008
I have just purchased a Philips DVP 5980 dvd player and QED Qunex P-CV1 component cables.When connected to my Philips 30PF9975/12 LCD all I get is a blank blue screen. The player works fine with a scart cable - just audio using component! Ideas anyone??
Comments:
Mar 10, 2008
- Tried your solutions but to no avail, all I get is 'picture format not available' flashing on and off. "Thanks for trying guys - any more ideas?" he asks hopefully.
Solution #1
posted on Mar 10, 2008
Somewhat Helpful)
avid_imps
Rank: Guru  Philips Expert
Rating: 86%, 409 votes
Assuming you have connected the DVD to the component (red / green / blue phono) connectors at the back of the set, and the TV is set to EXT5 then the problem is a setting on the DVP5980.
Check the Upscaling setting on the DVP5980 by pressing the HD UPSCALE button on the unit. Cycle through the options until you get a picture. The 30PF9975/12 is not fully HD compatible, so may only support the lower resolutions. (If any)
If this does not work, connect the DVP5980 with the scart and power on the without a disc in the tray.
Press Setup on the remote.
Press the right arrow button twice to get to the VideoSetup Page.
Move down to the Component setting an change from RGB to INTERLACE.
Disconnect the scart and connect the component lead. Select EXT 5 on the TV.
If the picture appears correctly, go back to the Video Setup Page and change the progressive option to On.
Was this helpful?
Yes
No
Popular Solutions for Philips 30PF9975 30 in. HDTV
Questions and Unsolved Problems for Philips 30PF9975 30 in. HDTV
Do you recommend Philips 30PF9975 30 in. HDTV LCD Television?
Answer
Answer
one day working fine , the next day no power getting to the set, checked power outlet. Even tried... (More)
Answer
i have a 30 philips flat screen that was working great then all of the sudden the screen went black... (More)
Answer
I have a 30'' Philips LCD flat screen TV hooked up to a PS3 with an HDMI cable. Whenever I switch to... (More)
Answer
I am going insane..... I have just purchased one of these and I cant get any sound, unfortunately... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 30PF9975 30 in. HDTV...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 769
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
