Canon i960 printer
The black ink cartridge is full on my ca**n 1960 printer. however, ** black in comes through on the pages. it seems that the head might be clogged. i've cleaned the heads through printer utility.is ther something else i can do to help the black ink flow through?
I've had luck taking the print head out of the printer and setting it on a damp paper towel til the ink wicks out. The black ink probably dried a bit in the head. at least it worked for me.
Good luck
Posted on Mar 10, 2008
My printer won't print black. ink is full, other colors print. Printer tests say everything o.k.
I would like to share with you my personal experience with printer issues. I have canon i455 printer which has black & blue color clogged. Here is the solution:
1. Buy Ethyl-alcohol/ethanol solution (70% or more). You can purchase this at any drug stores. Isopropyl alcohol may work as well.
2. Remove both cartridges from the printer head. Unplug the printer head from the printer body. Pour the alcohol liquid into paper towel layer (use more layer/thick to avoid ink from being drop into table).
3. put the printer head on the top of wet towel - with the face of HEAD touching the towel.
4. rub the head to the towel until you get rid of built-up ink on the head.
5. Pour some alcohol liquid into the printer head container (ink-receptacle area where the ink cartridge normally sits (there should be a little hole down in there where the ink actually flows from the cartridge into the head). Be careful do not touch the electronic parts. Let's dry overnight.
6. repeat step 2-5 if necessary.
7. Install the cartridge back to the printer and run several head cleaning maintenance, print nozzle check, repeat until no more dead nozzle shown.
good luck!
Dec 10, 2010 | Canon I960 InkJet Photo Printer
I960 won't print despite new print head
Hello!!
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
Feb 08, 2008 | Canon I960 InkJet Photo Printer
I just replaced the black and cyan ink in my i960 printer -- now nothing prints at all -- blank pages. I checked to make sure all of the packaging was off the cartridges
Run the Canon printer-software to launch a "print-head-cleaning" task,
because you may have "clogged" ink-jets, so that no ink can be sprayed onto the paper.
Test to see if FIXYA "censors" some words:
Start with the word CALM ( calm ) and swap the middle letters: **** ( **** ),
as in the ****-shell model of Apple portable computer,
or a cell-phone that opens like a ****-shell.
Do you see <star><star><star><star> instead of the word?
How about STUCK ( stuck ) and omit the 'T' to become: **** ( **** ),
as in "the printer sucks ink from the ink-tanks and jets the ink onto the paper".
Dec 06, 2010 | Canon I960 InkJet Photo Printer
Canon i960 won't print black
You'll need a new printhead, once they plug that bad nothing gets them clean again. Make sure the tape is off the top of the cartridge as well
Aug 07, 2009 | Cannon Canon i960 Photo Printer
No ink coming out on my Canon S900
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jun 29, 2009 | Canon S900 InkJet Printer
Canon i960 prints but no ink on page-new printhead (not clogged)
Sounds like the print head is no good. This happens. Here's a link to a site that sells them reasonably.
May 25, 2009 | Canon I960 InkJet Photo Printer
I was printing the other day and each page got lighter and lighter and now it doesn't print anything in black. There's ink in it and I turned off the printer. What else do I need to do to get it to print...
How long has it been since you printer prior to the other day ? If you do not use your printer for some time, the ink will dry out even if it's a new cartridge.
May 01, 2009 | Canon I960 InkJet Photo Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Canon i960 will not print in black ink
Yep same as above. Black prints very light gray after 5 years of good printing. Tried every test, replaced black cartridges with different brands. Just wondering if somehow you can clean the heads. I'm convinced the black head is almost totally clogged. Does anyone know how to remove the printer heas to do this?
Apr 01, 2008 | Canon I960 InkJet Photo Printer
Computers & Internet Logo
44 people viewed this question
Alun Cox
David Payne
David Payne
