Question about Vizio P2 42 in. HD-Ready Plasma Television
Verizon remote won't work
I have a Vizio 42 HD and the cable went bad. It was replaced but now the Verizon remote will not turn the set on and off plus it won't control the volume. I saw the Verizon tech try 3 different remotes but none would work. He said probably when the cable went out it did something to the volume and on/off. They work with the Vizio remote but not the Verizon remote. Verizon says it's not their problem and Vizio says it's not theirs. The set is 3 months old. Any thoughts?
  • Anonymous Mar 25, 2014
    Set can not be controlled with remote
    New Friend:
Try 1292 or 3145... These codes only allow me to control the volume, but that's better than nothing.....
Posted on Nov 30, 2015
I am a Verizon tech and the remotes we use work for Vizio sets just fine. If for some reason the remote wont work and he tried 3 different ones then it has to be your set. I set FIOS up all day and have no trouble with those TVs
Posted on Mar 10, 2008
My vizio e420vl turned itself off and won't turn back on. When i plug it in the vizio logo lights up amber but it won't do anything else.
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
May 29, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Original remote, cable remote or universal remote will not work on 42" vizio LCD Television?
you can get that board from shopjimmys.com
easy to change just plugs in-no adjustments needed
Sep 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
I'm watching football and cannot see the top score
You should adjust the aspect ratio on your cable box. Depending on your cable company there should be an aspect/HD zoom button. If this does not work go into the TV settings using the "menu" button and try to find a reference to aspect. Make sure it's set to 16:9 normal vs. stretch. You can contact Total COntrol Remotes (www.totalcontrolremotes.com) for help with this kind of issue.
Sep 06, 2009 | Vizio 42 in. LCD TV
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio Volume Control
I am sure you did this but recheck your audio menu on all your inputs. I have found that cables can go bad so make sure they are in good shape. Are you haveing the problems with all your inputs dvd, cable (direct cable or a cable box) whatever? It is hard to affect the audio by just moving the set. I am hoping that you changed something or the cables went bad that would be the easy solution.
Good Luck!
Aug 04, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio plasma tv turned off..won;t turn back on
This sounds like the main power board went bad. If this is still under warranty, contact 1-877-MYVIZIO and they will have it repaired for you. if not, let me know and I will guide you to the right part.
Jul 15, 2008 | Vizio P4 46 in. HD-Ready Plasma Television
Picture shifts to left
I had the offset left issue for non-HD channels with my Panasonic 42" plasma, using Comcast HD cable box. Went into the configuration menu (to get there with the newer Comcast boxes, you have to turn the box off, then hit the menu button on the box immediately after). You will see on the menu a resolution (probably says 1080i), then below it a "4:3 override". Our said 480i. When I changed it to "none", so that it stayed 1080i, it worked! It also works by selecting 480p, but then the picture is stretched.
Mar 13, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio "no signal"
We just had this problem and it was the cable that came with the set. Once we replace this, it received a picture, however, now the volume and on/off does not work on the Verizon remote.
Jan 31, 2008 | Vizio GV42L 42 in. LCD Television
Tv not changing channels.
This likely has a bad main board.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 05, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
413 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
