Question about Refrigerators
2002 Kenmore 160.61 Refrig / freezer (top)
The fan in the freezer has stopped running. A look shows that everything appears in working order; other then the fan which also blows the cooler air into the lower unit. Could it be the fan or the defrost timer. A look at the defrost timer shows that it is running via a plastic wheel viewable by a clear plastic cover.
  • 52 Answers
I assume that you noticed a loss of cooling in the refrigerator and freezer? In order to tell if it's the defrost timer, a good idea would be to check and see if there is a large amount of ice behind the interior back panel of the freezer (where the evap fan motor is located). If there is, you most likely have a defrost problem. There should be some frost, but it shouldn't be thick chunks of ice.
Otherwise, you probably just need to replace the fan. If you have a GE that takes an electronic control board, you may need to replace it as well. Please let me know if you have any more questions.
Posted on Mar 10, 2008
Kenmore 18tfa top freezer refrig model # 72852101 freezer works, no cool air going into the refrig part. Ice machine works fine too. fan is on.
Possible fan not blowing the air into the fresh food compartment or your freezer could be frosted up. Need more input.
Jan 29, 2011 | Kenmore Refrigerators
I have a GE refrig. model GTS22ZCMARCC. The evaporator fan has been pulsing up and down forever. Then the freezer stopped getting cold and the refrig. part was not as cold. I check the evaporator fan...
it's the board,also change out the sensor that's on top of the coil,it looks like a white bullet,the part number for the temp. sensor is wr55x10025 and the board is WR55X10942.everything runs through the board,i've seen when you call for water the compressor stops or the water doesn't dispense,or the fan pulsates like you have.let me know how you make out
Oct 21, 2010 | GE GTS18SHPBS Top Freezer Refrigerator
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
I have ice in the refrig compartment at the top and freezer fan is not working
if fan is not working it will ice up , most likely bad fan ,remove fan and test it and see if it runs out of frig , or have it tested might need to replace fan
Feb 03, 2009 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
