Question about Maytag MTW5600TQ Top Load Washer
Washer discharges Water during Agitation
We bought this washer new two months ago and ever since installed you can hear a small amount of water leakage through the discharge hose druing agitation. The higher the water level the more the leakage. It seems to be primarily during the wash cycle.
I read the manual and it says the minimum height of a standpipe drain is 39 inches and mine is 33 inches. The standpipe is in a wall unit so I don't have the option of extending the standpipe.
We had a Whirlpool washer for many years in the same location and ***** had this problem. We called the service center the retailer uses and they said that is normal for all the new washers, (hog wash)!
Have any ideas?
    Genius:
  • 3,587 Answers
You might consider raising the washer about 6 inches to make this work. it's vital to the operation of the machine..
Posted on Mar 09, 2008
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
Mildew smell coming from washer and getting stronger daily. I have shook washer and there appears to be a small amount of water sloshing around after I have tried multiple times to spin it out. Approx...
What you need to do is run washing machine cleaner through the machine, typically monthly. Do not disassemble, you will not find anything that you can help with.
Also, be certain that you are having successful vacuum break at the discharge point of the drain hose. Sometimes you can draw water back into the machine. BE sure that you have a p trap on the drain into which you are draining.
Apr 12, 2011 | Estate TAWX700JQ Top Load Washer
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
When you start a cycle, a small amount of water will run into the washer and it will sit and do nothing then the pause button flashes. But it will not finish a load even if you continue to hit the pause...
The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Apr 01, 2009 | GE WBVH6240F Front Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
My washer will not fill during the cycle for high agitation
You may have a siphoning problem. Double check your drain hose and make sure it's not shoved down in the standpipe too far. The standpipe is the drain line at the wall. If your drain hose is placed too deep into the standpipe, or if you have the top of the standpipe sealed off, the washer will begin to fill and continue to drain at the same time. The symptom will appear as if the washer is constantly filling. You need to leave an air gap opening around the rim of the standpipe, and the drain hose should only be placed about 4 to 6 inches into the drain line. I hope this helps you. Post back if this is not the problem you are experiencing and I will try to provide you with a better solution. Let me know if you have any questions.
Apr 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Squeaking Top Load GE Washer
I bought a new GE Washer GTWN5050MWS yesterday. From the first load it squeaked each time the tub moved back and forth (no agitator in the infusion type) It is a quick squeak and kind of resembles a cat getting it's tail under a moving rocking chair. I checked the entire owners manual and it describes several noises and not one of them describes what my new washer is doing. It does not make this sound except for when it is in the wash cycle. Spinning is quiet, and during the agitation of the rinse cycle it is a much more subdued squeak. But during the wash cycle it is not acceptable.
I called GE this morning and they told me it was normal operation for all infuser types of their washer to make this noise. Tomorrow I will be taking it back for a full refund.
We purchased this machine because our 2-year old front loading GE washer broke down (discharge pump I think) and to get it fixed usually takes a couple of weeks. We thought it might be better to have a 2nd washing machine instead of paying the laundry mat. It took a month to get the last one declared unfixable in 2008. Maybe I was wrong. But this is very bad luck to have a brand new washing machine squeak so loud out of the box.
Mar 15, 2008 | GE Profile WPRE6100G Top Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
6 months old. Now no water will fill drum! Works as normal but no water!
Hurlewan Your washer is still under manufacturer's warranty which is one full year. If it has Kenmore's name on it you do not need proof of purchase. The only thing you need is your mother-in-law's home phone number at time of purchase because Sears keeps all their records based on phone numbers. Good luck, Gendos post back....
Jun 27, 2007 | Kenmore 43142 Front Load Washer
Maytag MTW5600TQ Top Load Washer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
