Question about Denon DHT500SD System
PROTECT saying protect then switching to standby
I would say to check your manual, and if not, get it repaired (if you can). If you need to use a last resort, then just replace your dvd player with a new one.
Posted on Jun 17, 2008
I have this issue, my teac ag d7900 which itself off to standby and when I switch it "on" again, it says protect and shut itself down again
Right. This means that either you have a short in your speaker cable somewhere or the short-detector circuitry inside has problems. Disconnect all speaker cables and turn the receiver on. If the symptom goes away, turn the receiver off again and connect one of the speaker wires. Repeat until it starts to go into protect again. When it does, the last speaker you hooked up has a short somewhere in the wire.
If protect always comes on, you'll need to get the unit serviced.
Jun 28, 2015 | Teac Audio Players & Recorders
When you press the standby button to turn the system on it comes up with 'PROTECT' and then says 'SEE YOU' and switches itself off - how can I get rid of this?
hi,
ur systems output amplifier have some problem. there may be voltage at its output, that's why its go to standby to protect ur speakers. check the output amplifier stage,
ok
Dec 23, 2010 | JVC UX-S57 CD Shelf System
ONLY TURN STANDBY
Hi.
The standby is forced because a fault had been detected.
The TV is in protect mode, because a fault had been detected.
If the TV went in standby and does not wake up, then the TV is in protect mode.
In protect mode higher voltages from PSU gets shut down and TV remains in standby.(see also Why my TV does not start up and remains in...)
Try first leaving the TVpower cord unplugged for some times, let say one hour or so. Then connect powr
If that does not work, and you keep having the TV in protect mode, it means that there is a fault.
In that case call the phone support number listed on the user manual to arrange repair.
If you want DIY you find parts here: Memorex TV Parts | ShopJimmy
Jun 12, 2010 | Memorex MLT1532 LCD TV
After turning ON the power/standby switch, the unit(receiver) display comes ON (green light) then after approx.4-5 seconds the display goes OFF and the unit defaults back to the standby mode (red light). I...
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure.
Protect mode can result from speaker wires touching each other or the Amps2_bing.gif metal case. Check that first.
It can also be caused by unstable ohm loads if too many speakers2_bing.gif are connected to any of the outputs especially zone 2.
If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
Nov 16, 2009 | Denon AVR-485 Receiver
When i press power on it says push power to protect.When i press power it says standby and then powers off.
the unit has put its self into preotect mode for a reason.
you can trr unplugging the dvd plyer from the wall, that should reset it
May 03, 2009 | Sony MHC-ZX70DVD System
Re: Denon AVR-1100 receiver Just powered it on after years of not being used, although I know it works just fine. Powers on fine, but the readout on the screen says "AUTO" (small) and "PROTECT" (large) and...
The receiver has gone into a protect mode because something is wrong and it shuts down to prevent further damage. Could be a power supply or output amp issue.
Jun 20, 2017 | Audio Players & Recorders
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
Startup
Going into protect due to either blown channel or probably a 15v regulator might be down which I have seen many times also. causing unit to go into protect.
Jan 21, 2008 | Denon AVR-3806 Receiver
Denon surround saying protect on display
Make sure none of your speaker wires are touching, this will cause it to shut down instantly.
Oct 15, 2007 | Denon DHT500SD System
Flashing PROTECT
This is often caused by a problem with the speakers or speaker wiring. A speaker wire that's pinched behind the head unit will cause this problem if it's shorted to dash metal or the deck chassis. The first thing to do is remove the head unit and inspect all the speaker wiring for bare spots or pinched spots. If everything looks okay, disconnect all four speakers from the deck and switch it on. If it still shows "protect" then you have a defective head unit. If not, then turn it off, re-connect one of the speakers, and turn it on again. Continue until you find the speaker output that puts the deck into protect mode.
Jun 25, 2007 | Kenwood KDC-MP4032 CD Player
Denon DHT500SD System Logo
69 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
