Question about Refrigerators
We have an LG Model LRFD 22850ST Fridge with ice F1600/2399. Every time you pull the ice bucket to get some ice, cubes of ice fall over the bottom of the fridge. Is there a retrofit to fix this annoying problem?
I ***** got the call back, don't know why the first post blanked out *****.
Posted on Mar 09, 2008
  • 878 Answers
Thunder, I ran into a couple of these, bottom freezer with the same problem, I got a hold of LG and they came out with a different bailing arm on the ice maker. Part number mfc39559901. When I received the part, it almost looked identical to the arm that was on the ice maker. I replaced it anyway and ***** got the call back, but I'm still a little miffed by it. The part is around 8.00, you can get it at Catriver.
Lg fridge not making ice all of a sudden
It just may actually be frozen lol. Try defrosting the freezer and see If it works after that
Nov 27, 2017 | Miscellaneous
My ref/frez is out of plumb- how do you adjust the feet?
I found a solution in another question for a different fridge. I believe the solenoid that opens and closes the trap door for the ice is not functioning, causing the ice to either always crush or stay cubed, depending on the orientation of the metal rod that runs along the bottom of the ice bucket. Pull out the bucket and slightly twist this metal rod in the opposite direction, reinsert the bucket, and you should now have the opposite of what you had before (crushed vs cubed, vice versa). The solenoid should rotate this rod for you, but if it's busted then that doesn't happen. If you always use one type of ice, you'll be fine, but if you want to choose between crushed/cubed, you'll probably need to replace this solenoid.
Jul 09, 2013 | Kenmore Top Freezer Refrigerator
When I choose either cubes or crushed on my icemaker, my unit only crushes the ice. I already had the water inlet control valve replaced and there are plenty of cubes in the bin. It is a dispensing issue...
this manufacture makes 2 seperate style ice buckets one in the door and one in freezer with a large ice bucket and auger screw that turns... first we will explain the one up on a shelf in freezer side up top... if you pull your ice bucket completely out of freezer... there should be a small bar coming out of rear toward bottom of ice bucket assembly now put it back in where you got it but this time watch where the rod goes... there is a solenoid in the rear of freezer actually called cube/crush solenoid and what this does is if switched to crush will raise that rod and activate the teeth in bucket to crush ice... if not will let ice fall out in whole piece...this solenoid sometimes gets hung or will freeze ...make sure with your finger you can move it freely and then watch it with some assistant pushing the switch for you does it go up when the handle is hit... the ice bucket in door works the same way except the componets are in the door and a little harder to access... repost with any questions if this doen not help you out...good luck to you
Jan 19, 2011 | Whirlpool Refrigerators
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Jun 06, 2010 | LG LSC26905TT Side by Side Refrigerator
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
My ice maker stopped working. Yesterday I emptied the ice bucket as a bunch of cubes were frozen together and it would dispense. I've turned it on and off but nothing. There is no ice in the bucket and the...
You need a new water valve on your LG fridge. This is a simpe repair and we have parts so just contact us with your beand and model number.
We look forward to working with you.
Nov 04, 2009 | LG LRFD25850 French Door Refrigerator
The crusher function on ice making part of my Maytag Zigzag fridge freezer is not working. I have ice cubes but no crushed ice
pull the bucket and check the solenoid on the back wall this is what shifts the bucket to crushed and cubed
Jul 31, 2008 | Maytag Refrigerators
GE Monogram ZICP360SRSS - Ice cubes spill out of icemaker bucket
sorry, but not unless you want to get into spending some serious time.
Jul 29, 2008 | GE Refrigerators
Refrigerators Logo
177 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
