Subwoofer noise Sub suddenly makes loud buzzing sound and air blows through hole in bottom of sub when stereo/home theater system is off. Sub works fine when stereo/home theater system is on.I have tried turning sub off and back on, **ise comes back eventually. I have tried uplugging power supply at sub and receiver to reset, ** luck!
  • Anonymous Mar 22, 2014
    What is the sequence for removing the screws on the back of the DPS10? I have a loud buzz unless downward pressure is applied to the connection of the RCA cable. I think it is a grounding issue with the connectino inside the sub. I removed all of the wood screws from around the back panel and 4 smaller screws but the panel wont come off.
  • Anonymous Mar 30, 2014
    Sub intermittently makes a clicking kind of noise. Tried unplugging for a day and came back after 5 min of being plugged back in. Does it even in standby.
  • 56 Answers
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Posted on Mar 10, 2008
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
The subwoofer starts to make a loud thumping sound
Remove the signal source and power it on to see if the problem occurs without any input signal. The problem could be in the receiver and not the sub
Dec 08, 2013 | Cerwin Vega Avs-sub8 150 Watt Amplified...
No sound from sub
  1. Are the stereo speaker wires run to the subwoofer and out to the stereo speakers
  2. Make sure the notch filter is off
  3. Refer to the manual on line: http://www.manualslib.com/manual/105794/Mordaunt-Short-Ms909w.html?page=7#manual
  4. READ THE MANUAL
Nov 12, 2013 | Mordaunt Short Aviano 7 - Powered...
Subwoofer continuous buzz/signal noise
I just bought mine yesterday and have the same problem... did you find a solution (other than throwing it out the window)?
Nov 18, 2009 | Bose Acoustimass 15 System
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Kef Kit100 subwoofer buzzing
You have a bad set of Audio output IC's for the sub. There is two of them. TDA7293 REPLACE BOTH!!!
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25.
Jan 18, 2009 | KEF Audio KIT100 System
I have a kef Kit100. My subwoofer is making a loud buzzing noise, what do I do?
You might have a bunch of bees living inside the sub?
KEF KIT100 Buzzing
There is 4 on one side of board,and 2 on other "also 1 small one" The the two are for the sub,the other 4 are for the main speakers/surround. They sell on Ebay for $6-10 each or a kit of all 6 for $25. I would replace all 6 on your system. To insure that the other's do not go bad after fixing the bad ones.
Dec 03, 2008 | KEF Audio KIT100 System
Infinity ps-10 powers up but no boom
Try hooking up a different signal input to your powered sub, another stereo or even a dvd players audio output to the sub will work for a test. Just make sure the subs gain is down before starting. If it still not producing sound, the subwoofers amplifier is bad. I hope this helps.
Oct 10, 2008 | Infinity PS-10 Subwoofer
Sony Active Subwoofer noise
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Dan
Mar 09, 2008 | Audio Players & Recorders
669 people viewed this question
 Grubhead
Grubhead
