Router How can i access my router in order to apply my password? Thanks Guys.
  • 3,587 Answers
Depending on who's router, it's usually by entering or a variation on that. check the model maker and go to their website, and instructions are usually there..
Posted on Mar 09, 2008
How to set up an wireless password on my linksys? please help. thanks
Hi there.
Type this into your web browser:
It will bring you to the Linksys setup page.
A window will pop up prompting you for a username and password to access the configuration page for your router. Enter "admin" (without quotes) for both the username and password.
From there you can change your router name if you feel like it.
click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use the same name you set as your Router Name in the previous step. Then Disable the Wireless SSID Broadcast option and click Save Settings.
Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 128 bits 26 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. Finally click Save Settings.
Thank you for using Fixya!
Jun 28, 2011 | Computers & Internet
To secure the router, first you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually (Default IP Address and it is also written at the back of router) and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password admin.)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method WEP or WPA (preferably WPA2)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Also, you may refer here for some additional details
Hope it helps! Good Luck! Thanks for using Fixya!
Jun 17, 2011 | Linksys Wireless-G WRT54G Router
Hit reset button on router......wanting to change to my own username and will not work after i thought i applied my settings
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. or or or If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jan 16, 2011 | Belkin Wireless Surf Router (F7D2301)
WHenever i am trying to connect to the internet, it says the network password has been changed. About 3 guys has had access to this property. Is there any way possible that this can be fixed?
First Uninstall the Router Monitor Software from your computer ! as it is the reason for most of the issues with this router
To Setup a new wireless connection follow the steps below
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 11, 2010 | Belkin Wireless Surf Router (F7D2301)
Hi, I bought Asus Wireless Router RT-N13U. I notice that there was no entry of password for security, which means anybody (even neighbors) can access this router? Did I miss anything during the setup? How...
You need to enable WEP or WPA or WAP in wireless security. For that access your wireless router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. or or or If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then enable WEP security enter Password then apply and save settings then restart router . Then only those can connect who know that password. . Let me know if you need further assistance. Thanks for using FixYa.
Aug 09, 2010 | ASUS Computers & Internet
Need a securty code
Regarding your concern, please note that in order to get the network key/password on the NETGEAR router (MODEL_NUMBER), we need to login to the router's web interface using any computer which is physically connected to the router.
Please follow the steps on a computer connected to the router using an Ethernet cable in order to find the network/security key:
1. Open the browser (like Internet Explorer, Mozilla Firefox, or Safari).
2. Access the router, usually by typing '', '' or '' in the address bar.
3. When prompted for Username and Password please enter Username as 'admin' and Password as 'password' (please note that both Username and Password are case sensitive).
4. Click on Wireless Settings' under Setup from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the pass phrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the NETGEAR router's wireless network.
In some cases, for security reasons the pass phrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Feb 07, 2010 | NetGear WGR614 Router
Change of current belkin N150 password.
Contact Belkin for Care at 1-800-585-2494 Toll Free.
Sep 14, 2009 | Belkin (F5D8231-4) Wireless Router...
Blingking light, no access to internet
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} FULL SETTINGS
  • connect it based on the manual
    • set first the routers access page
    • type
    • type username: admin, password: password
    • on basic settings: select no internet login: set the router mac address to set to computer mac address, apply
    • click: wireless settings under set-up: change: SSID: <your name>, region: US, mode: g&B, channel: 11, no password first, click apply
Aug 03, 2009 | NetGear WGT624 Wireless Router
Having trouble accessing router with ipod touch and nintindo dsi
In order to Unlock Netgear router you need to know the login password for router's login page and if that does not work, you can try with a default username : admin, Password : admin, still if you are unable to access the routers page then you need to reset the router by inserting a pin in the pinhole where it says reset at the back of the and hold down the pin for 30 seconds and then restart the router, this will take the router back to default settings and then apply username : admin and password : should work
Netgear address : ( Type in IE address bar to access it )
Apr 06, 2009 | NetGear WGR614 Wireless Router
Zyxel wireless router password
hi . do you guys cant access to your wireless router ? if yes than try this
reset your modem by pressing reset button on your modem for more than 5 seconds so all the information entered will be gone including your password
than insert your modem CD and connect to your modem
set up your internet again
put your password and user name that your ISP gave you
set : get IP from ISP
get DNS from ISP
than go to wireless setting
use wpa- personal
and set up a new password eg. (usa2008)
than it will say your computers and network setting doesnt match
go to connect find your modem
right click on it
click on properties
than go security
choose WPA- personal
and your password (usa2008) you set to your modem
connect to your internet
im not sure if this is what you mean / thats how i anderstood your problem
BECAUSE IT WILL DELETE ALL INFORMATION IN YOUR MODEM including user name / password / IP / DNS / and your modems password
Aug 17, 2008 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
