Question about Kenmore 44072 Front Load Washer
Hot water on cold water wash or rinse
** matter what cycle I use, the rinse and spin cycle are hot even though I have it on cold. What do I need to do to have a cold water rinse? I know the hot and cold water are hooked up correctly.
  • Anonymous Apr 01, 2014
    Get all hot or all cold water regardless of cycle.
    Genius:
  • 3,587 Answers
Hmmm..now that's really interesting..that's a function of the control board..methinks you have an error in the panel and control center.
Posted on Mar 09, 2008
I load washer it starts the wash cycle it goes through wash cycle fine drains water but does not collect water for rinse cycle it just idles. So I turn knob to spin and it spins until done.
If it doesn't fill for the rinse, I would say that the cold inlet valve has failed. Check that the cold tap is turned on and check when the machine fills for the wash cycle and see if it is taking hot or cold water. You will probably find that it is filling only with hot water. A local spares store should have the valve you need.
Sep 17, 2015 | Whirlpool Ultimate Care II LSQ9564J Top...
NO WATER INTAKE WHILE RINSE OPTION IS ON
It sound like the cold water inlet valve is faulty, the rinse cycle uses only cold water, and the water in the 'wash' cycle is probably hot.You need a new inlet valve, which on your machine is probably a double hot/cold unit.If you can't get a new inlet valve, a handyman/electrician may be able to change the wiring to use the 'hot' inlet valve for cold water which will allow the machine to wash, and rinse, using cold water through the hot valve..Tikka?...Good luck...Nomess
Jun 01, 2010 | LG WFT1071TP Top Load Washer
The washing machine won't start if "cold water" only is selected. It will only work when "warm water" or "hot water" is selected (and even then there is only hot water filling the machine, the cold water...
Check the cold water solenoid. If a meter is not available you can swap the hot and cold wires and see if the symptom changes to hot water when cold is selected. If so the mixing valve needs replaced. If no then further testing of the wire harness and timer circuit are needed.
Eric
Apr 13, 2010 | Kenmore 13202 Top Load Washer
Cold fill washing machines
If your washer is the type that all rinses are in cold water only this would make sense that in the winter months when the water is at it's coldest the clothes will feel cold after the spin cycle.
If your washer has a warm rinse cycle and when you select the warm rinse option the clothes feel cold after the spin, then maybe the hot water supply line is plugged.I recommend disconnecting the hot water hose at the back of the washer and check the screen that is at the fill valve on the washer and make sure it isn't clogged with sediment or calcium build up or any other foreign material that would keep the hot water from entering the washer.If all is well there, suspect either the water temp selector switch or the hot water fill valve. Good luck !
Jan 23, 2010 | Washing Machines
My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Nov 27, 2009 | Daewoo Washing Machines
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Kenmore 44072 Front Load Washer Logo
186 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
