Sony Active Subwoofer noise
Subwoofer suddenly makes loud buzzing sound when system is off, and air blows through hole in bottom of sub. Noise goes away when turned off. It comes back later for ** reason. Sub works fine when whole system is in use. I tried unplugging power supply form sub and receiver in hopes of resetting sub, ** luck. Is it the sub or something else.
  • Anonymous Dec 14, 2008
    I have that same sub with the same problem, but have found the solution. Seehttp://www.sunfire.com/sub_faq.html#set_... and look at "why does my system have a loud hum." The splitter may help some, but only because it is splitting the signal that is causing the problem, that signal will still be amplified, but just not as strong. Try THIS: turn the crossover all the way down to 40hz and slowly turn the volume up from zero. Leave the volume just below the point where it starts to hum/buzz. You can turn the crossover up a bit too. I have mine set at about 80hz and the volume a little less than half way up. It sounds good this way, any louder and the sub is too loud when the speakers are low. With these settings I don't get the hum when turning the receiver off. If you don't like the sound this way you will have to fix your ground/signal problems as stated in the link.
Need a schematic for a sony sawmsp1 active subwoofer....anyone????
Posted on Jul 17, 2009
  • 4,234 Answers
The circuit that should be turning the sub on and off based upon the presence of an audio signal is not working correctly and the sub is trying to reproduce 60 cycle hum. The unit needs service.
Dan
Posted on Mar 20, 2008
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Why is the subwoofer making a buzzing sound? Is there a solution?
I have had the same problem with my Sony sub. It sounds like it is picking up electrical noise and would not go into standby when the reciever was off. I rerouted my wires and changed to a much higher quality wire. I was using a very low quality stranded copper with thin insulation to start with.
Jun 14, 2010 | Sony SA-WM20 Subwoofer
Constant noise from Mirage NanoSat 5.1 System Subwoofer
sounds like an earth fault either with the plug circut or more likely with the power board of the unit.
Jan 06, 2010 | Mirage NANOSAT 5.1 System System
Subwoofer problem
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your reciever feed at the entry point to your system.
Dec 23, 2009 | JVC RX-6018V Receiver
Subwoofer continuous buzz/signal noise
I just bought mine yesterday and have the same problem... did you find a solution (other than throwing it out the window)?
Nov 18, 2009 | Bose Acoustimass 15 System
Loud buzzing from Kef PSW1000 Subwoofer
yes. A good idea. Kill power to the sub, then unplug and remove everything from the sub. go ahead and plug it in again and check for buzzzz.
That is test one. if you have buzz still, its the sub assembly. bad luck, but not impossible. If the buzz is gone its one of the signals to the sub. They can produce a buzzz without any signal coming from your stereo equipment. Replace the feed line, enjoy! BTW...Kef sure does sound clean. good choice.
Nov 09, 2009 | KEF Audio PSW 1000 Subwoofer
Subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Mar 09, 2008 | Audio Players & Recorders
HS 500 noise from subwoofer
Well as I see from the owner manual for this device the sub is active one and my opinion is that electric is your problem.The power of the sub and main unit must be on the same phase otherwise you'll hear brrrrr or frequency of your main unit power supply on the sub.Thats why sound changes when you open or close the door.Take one power distribution cord (get power for bought devices from the same place) and connect main unit and the sub on it and then try.I hope that this will help you
Mar 04, 2008 | Audio Players & Recorders
Buzzing noise - loud
check for dirt in the air gap that is formed between the electromagnet and the contact form. if there are any shading coils on the magnet check for a broken one.
Dec 30, 2007 | Dayton U33/U32 Utility Heater
Loud buzzing noise
Bad connections or faulty wires check the wires and the connection of the wires, usually the buzz is a bad earth
Nov 16, 2007 | Acoustic A-5640 Computer Speakers
865 people viewed this question
 Grubhead
Grubhead
