Question about Kitchen Ranges
How do you simmer or use small pots on a viking gas stove? I can't get the gas low enough to make rice.
    Scholar:
  • 76 Answers
This appears to be a commercial unit, in which case if you are using it at home, you probably are using a pot that is too small.
Posted on Mar 09, 2008
  • Donovan Michie
    Donovan Michie Mar 09, 2008
    Try a larger pot, you will have to use more water too. This doesn't mean you have to cook rice for 20 people, it means you use a larger pot and more water.
5فغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغغ
What is the difference between a stew and a casserole?
A stew is cooked on a stove or over a fire and a casserole is cooked evenly in an oven. As well, casseroles are cooked either covered or not, while stews are usually covered so they don't evaporate.
Jan 14, 2013 | Home
Can't simmer
Some models have a hollow stem. Remove the knob and use a sall screwdriver to tweak the flame.
VIKING
Sep 30, 2012 | Kitchen Ranges
Carbon residue on pots
There is an adjustment for correcting the air mixture on the gas line going from the knob to the burner. It usually is located at the point where the adapter nozzle enters the gas line going to the burner.
Aug 13, 2017 | Kitchen Ranges
I have a Kitchenaide model KGSS907SBL01 gas range. Everything works fine except that we find that the amount of heat generated is disappointing. This seems to come from the fact that the top of the grill...
It would seem like reasonable thing to do.However the adjustment is typically for the low setting so you can adjust just the small flame just enough to simmer a pot without the flame going out from being so low its susuptable to going out on the low setting, also it so you can adjust the flame smaller so on low it isnt too high,causing it will boil when you intend to only simmer a dish your cooking. A question;is it all burners and have they always been that way?
Gene
Aug 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
Flame on my Whirlpool gas stove burners are too high on low
either turn down the gas knob or turn knobs to lowest setting without going out. That is about your only options
Aug 25, 2009 | Whirlpool SF367 Gas Kitchen Range
Low Flame is too high to simmer
there should be a regulator between the stove and the main gas line .unscrew lock nut turn valve clockwise to turn gas down. turn down too far , will turn gas off.
Jul 30, 2009 | Kitchen Ranges
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Burner goes out on simmer
look down the shaft of the burner valve(remove the knob). with a very thin and somewhat long screwdriver you should be able to adjust this flame, with the burner on MED hold the shaft of the valve with a pair of pliers and turn the screw slowly( you'll need to hold the shaft tightly because if not you'll be turning shaft and not adjustment screw. small increments yield big changes in flame
Mar 07, 2008 | Roper FGP325K Gas Kitchen Range
Simmer is to hot
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Oct 31, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
Kitchen Ranges Logo
184 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
