Question about HP Deskjet 5440 InkJet Photo Printer
Hp 5400 is anyone can help me how to fix my hp5440 printer? it never print and it said hp5400 offline? Printer fails to print and it automatically goes off line. I double checked everything making sure that everything is ready. Please help.
    Genius:
  • 3,587 Answers
Maybe you need new driver for that printer? get it here
Posted on Mar 09, 2008
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Says disconnected but it isn't
I have put together a couple off guides for troubleshooting different offline printer issues for Windows XP, Vista and 7. I would recommend checking them out here: http://www.refreshcartridges.co.uk/igloo/how-to-make-your-offline-printer-online/
Hope they help.
Apr 12, 2013 | HP Photosmart C6280 Printer
Printers driving me crazy; I have three HP printers and none will print for me now
To Add and set as Defult Printer Go to system Preferences>Print and Scan > "+" symbol on left corner and add the printer.
when you give a command of print there you can see the list of printers and you can select the printer you want to print from.
Oct 29, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
HP Photosmart C6180 All-in-one Offline mode
Go to www.hp.com. let the PRINTERS section auto-detect your printer and download the drivers automatically.
Jun 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp 5400 printer continuously shows as offline
If you are one a Mac, I may be able to help, as this happens to me. Sometimes when I send a print job, the printer shows as offline. HP recommends turning the printer off and then back on, but this did not always correct the problem. Go the the Printer Queue, click on the print job and then click on Pause Printer. Count to 10, then click on Resume. This fixes the problem for me and the printer then prints the job. I am running OS X 10.5.7. This same problem occurred using OSX 10.4.x
May 29, 2009 | HP Officejet Pro K5400n - - colour -...
Printer won't print says it's offline
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
Apr 04, 2009 | HP Deskjet F340 All-In-One Printer
Printer light keeps blinking and status stays offline even it is READY
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
Nov 14, 2007 | HP Deskjet D2360 InkJet Printer
HP Deskjet 5440 InkJet Photo Printer Logo
161 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
