Question about Refrigerators
Refridgerator freezes everything, including items in bottom section
  • 1 more comment
  • Anonymous Feb 11, 2009
    Same thing.
  • kfsmith11 Apr 27, 2009
    refridgerator freezes everything, and water filter is frozen as well, so the water feature does not dispense water. Already replaced the thermostat on fridge side. Any suggestions??
  • kfsmith11 May 11, 2010
    frigidaire, side by side,
    FRS26LF7DSB Freezes everything on refridgerator side, thermostat already been replaced. Still freezing.
    President:
  • Refrigerators Master
  • 2,651 Answers
Who makes it and the model if possible
Posted on Mar 10, 2008
Ge BOTTOM FREEZER REFRIDGERATOR FREEZING UP. Turned down temp but will freeze everything in top compartment
Most likely to be a leak or the door seal, give it a good clean spray with silicone and wipe again.
May 24, 2017 | GE Refrigerators
Whirlpool freezer on bottom refridgerator is freezing up
What does this mean? Liquid is freezing in the refer section? Food (like veggies or leafy items) What model do you have? How old is this unit? Who is requesting this information? I need your help in this too. Thanks.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 25, 2014 | Refrigerators
REFRIDGERATOR IS FREEZING EVERYTHING
You will need to replace the thermistor located under the control housing in the refrigerator section. Here is the part to order.
Nov 27, 2012 | Maytag MFI2569VE Bottom Freezer French...
I have a GE Profile Bottom Freezer Refridgerator. Everything I put in the fridge freezes. When I increase the temperature, it stays low.
Make sure you do not have items blocking air flow to the temperture sensor at the top left side of the refrigerator. Another thing to check would be air leakage at the air duct at the bottom back of the fresh foods section. Also, at that air duct, make sure there is an electrically activated dampener door inside (I've seen them missing), and that the damper door is not broken.
Mar 14, 2011 | GE Refrigerators
The food in the back of my refridgerator is freezing. Whats the recomended temperature.
You have your freezer over packed move items around use a med. temp. this well let the air circulate.
Jul 05, 2010 | LG LFC25770ST (250 cu ft) Bottom Freezer...
Freezing items in refridgerator
make sure the air passages are not blocked with food produts the other fix might be to un plug refrig and let it defrost for a day make sure you leave doors open
Dec 31, 2009 | GE GSS25LGM Side by Side Refrigerator
The refridgerator is not cooloing and the freezer is beginning to frost up
This sound if the blower motor in the freezer section is not working, everything freezes and the bottom does not cool, you will need to remove the cover in the back of the freezer and if the fan is not working it will need to be replaced
Oct 30, 2009 | Refrigerators
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
Refridgerator
check to see if the fan is running in the freezer section if not start there to see wht is bad, motor, loose fan blade, obstruction of fan blade, electrial issue at motor
Apr 11, 2008 | Refrigerators
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
