Question about Electronics - Others
Sandisk Format Hi Im using a sandisk 4gb sdhc card in my Canon A640 digital camera. Recently I tried to use the card to store some video for playback on a PC. I put the card in a USB card reader and tried to put the video on the card. I get a message saying that the card has not been formatted , would I like to format it? When I press the "yes" button I then get another message saying that there isnt a disk in "F" drive, please insert disk and try again. I would be very happy if you can come up with a solution. Thanks in advance Dean
  • akwaholic Mar 13, 2008
    What kind of a %$#&witt are you?
  • ram85kumar Dec 14, 2008
    i have the same problem. when i insert my stck pro ad card into the drivewhen i want to see the pictures in that i it is asaying insert disk into the drive.
    can anybody solve my problem? thanks.
JUST PUT IT IN TO WATER,THEM EVERYTHING WILL BE ALRIGHT.
Posted on Mar 12, 2008
I have a Canon PowerShot A540 Digital Camera I got a new memory card it is a sandisk SDHC 8 GB but I am getting a memory card error message.... What can I do?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problemlisted here.
Oct 01, 2011 | Canon PowerShot A540 Digital Camera
My canon powershot a640 comes up with the message...........................NO MEMORY CARD i have eliminated the memory cards, what else can it be?
The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out.
Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card).
In this link could find some troubleshooting tips: fix-for-memory-card-error.
hope helps.
May 03, 2011 | Canon PowerShot A640 Digital Camera
I have a SanDisk SDHC Card class 4 4 gb and it won't work in my Canon Power shot SD630, I get a memory error that says card is locked, however card is not locked, what camera canI use this card in?
The SD630 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
Your SDHC card can be used in any camera that accepts SDHC cards.
Feb 03, 2011 | SanDisk 4GB Secure Digital High Capacity...
It will not format a 4gb SanDisk SD card
Your 4GB card is actually an SDHC card. The DX6490 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with SD cards 2GB and smaller.
Nov 28, 2010 | Kodak EasyShare DX6490 Digital Camera
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
Have a Kodak EasyShare C743, bought a SanDisk, won't format
Your camera was designed before the SDHC format came out. Sorry, your camera can only use standard SD cards, those usually 2GB or less. An SDHC card will not be recognized properly by your camera. If you really want to use a 4GB card, do a Google search for SD and "non hc", with the non hc in quotes. Believe that Transcend makes one.
Apr 24, 2010 | Cameras
I want to upgrade the memory card of my Canon PowerShot A570is. What memory card should I buy? The last that I had was a SanDisk 1.0 GB.
The camera supports SDHC memory cards, so any SDHC card should work.  If you shoot video the cards with the faster write speeds are better.  The SanDisk 4GB or 8GB cards should work well.
Apr 26, 2009 | Canon Cameras
Canon zr200 wont format new 4gb sandisk card...why?
The ZR200 is able to read a card of maximum of 2 Gbytes !!!
The 4 GB SD card it is a so called SDHC = Secure Digital High Capacity ! Every SD card with more than 2 G Bytes it is a High Capacity and the old hardware will not be able to use these SDHC.
Jan 11, 2009 | Canon ZR200 Mini DV Digital Camcorder
Sandisk memory card
Has this card EVER worked with your camera? Since you didn't mention the model number of the Canon, it's possible that you have a compatiblity issue here. Most 4GB SD cards these days are actually SDHC cards, which store memory differently (in sectors, like a hard disc drive, rather than bytes, like your main memory). All SDHC compatible cameras also support SD cards, but cameras sold before the SDHC standard was created will not support SDHC memory cards.
There's a chance that Canon has a firmware upgrade to solve this. You would have to look on the Canon USA web site for this, based on the model number of your camera.
Jan 20, 2008 | Cameras
Card Error on a 4GB SDHC Sandisk Memory Card
I went onto the BestBuys site and found a link for compatible memory cards - The SanDisk SDHC isn't compatible with the Canon Poswershot SD750!! Only a 2GB card will work. The Lexar SD and the Kingston Technology 2GB will.
Dec 19, 2007 | SanDisk 4GB Secure Digital High Capacity...
Electronics - Others Logo
155 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
