Question about AEG Lavamat 74640 Front Load Washer
Hotpoint washing machine drum suspension springs
Hi guys,
one of my springs supporting the drum has perished and is not holding the drum properly so it knocks how do i release the tension of the springs to replace for a new one ???
    Genius:
  • 3,587 Answers
That's a really intense operation..you'll need to remove the tub to do this. quite a job, actually..
Posted on Mar 09, 2008
Whirlpool LSN8244AW0 began making a loud thumping noise which quickly got worse then turned machine off; appears that tub is off balance and hitting all four of the inside walls during spin cycle. Do i...
The problem might be springs of the unit might be loosen or the suspension which holds the washing machine drum unit kindly replace the after checking which is faulty.It is difficult to find in spring but in suspension it must not go freely if if goes freely means kindly replace the suspension this problem will be solved
May 15, 2010 | Washing Machines
Washing machine is jumping around on the spin cycle
A few possibilities here.
Make sure the washer is level, both back to front, and side to side.
Do not over load, and make sure that there is more than 1 article in it, otherwise you will get an out of balance load.
Make sure the water is drainlng away properly.
Check the drum for excess movement, this would indicate a broken spring or worn drum bearings or worn or broken drum shaft.
Check the concrete wieghts at the top and bottom are not loose or broken.
Check the suspensions for excessive wear.
Hope this helps
Mar 31, 2010 | Maytag Performa PAV2200
I have a Hotpoint Aquarius WD 61 and when it is on, especially on spin mode, the machine makes a large banging noise. I think it may be a loose drum as there seems to be too much movement when i take a...
It is unlikely to be the springs as they do no not often break.
To check, remove the top cover, and you will see a spring at the front and rear of the drum, sometimes one can come unhooked.
Another possibility is loose or broken concrete balance wieght at bottom of drum, or worn suspensions, or possibly worn drum bearings or broken drum shaft.
The poosibilities are numerous.
Good luck in your search for a solution.
Mar 24, 2010 | Hotpoint Washing Machines
It seems that the drum is spinning off its axis
When a front load washer does not spin properly, the problem can be caused by failed axle that connects the pulley to the wash drum, or failed shock or (possibly) broken suspension springs.
Remove washer top, inspect the two or four springs holding the washer drum up. The whole drum should be able to "bounce" a little, when you press down on it.
Remove the lower front panel and with a flashlight, inspect the two shock absorbers. Both should attach up to the wash drum, but it is common for them to break, especially if the front load washer has been moved from one house to another without re-installing the lower brackets and the long bolts that secure the drum during the move.
If the springs and shocks are not damaged, with the top removed look down into the rear area. You will see a large pulley with a belt on it. If you see brown/black grease marks all over or obvious problem when you try to turn the pulley, you have found the major problem.
Please get back to me with what you find. OK?
Jan 03, 2010 | Hotpoint WMA58 Front Load Washer
How to I remove the drum from a Hotpoint WM64 washing machine? I need to change the bearings.
Remove top cover and rear panel.
Remove belt and drum drive pulley.Remove clamp that secures door seal
Remove top control console panel.
Remove door lock.
Remove screws top and bottom holding front panel, remove front panel.
Remove spring clips holding plastic drum front, lift to one side plastic drum front cover.
Tap drum shaft to remove drum from container, remove bearings.
Please rate my solution.
Thanks.
Sep 04, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do you remove drum springs on a hotpoint WMA washing machine
working from the front using mole grips get hold of the suspension peg now feel round the back you should feel a raised part of the peg this has to be depressed now pull the peg out if it gets stuck push back 5mm and try again repeat on other side life the springs out with the drum
hope that helps
May 13, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hi,my hotpoint wf541 washing machine has become noisy on its spin cycle,any ideas as to what is wrong with it,or can you recomend a repairer for me in Lincoln,uk?
Try spinning the drum by hand ,if it feels or sounds noisy, then the main bearings have gone, if no obvious niose, then it could be m/c not level, overloading,-loose balance weight)(s)-suspension spring broken or unhooked--there are other causes, but these are the usual things to look for.
Thanks.
Dec 29, 2008 | Hotpoint BWM12 Front Load Washer
AEG Lavamat 74640 Front Load Washer Logo
181 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
