1999 Mercury Sable Logo
Posted on Mar 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i change front brake pad on this car merecy sable 1989 -99
Anonymous
Level 3:
  • Master 2,317 Answers
  • Posted on Mar 16, 2010
Anonymous
Master
Level 3:
Answers
2317
Questions
Helped
788230
Points
7079
Remove the wheel, remove the 2 bolts holding on the caliper to the caliper carrier. You will need a large C-Clamp or a cailper piston tool. Place an old brake pad against the piston in the caliper and use the C-Clamp to push the brake pad against the piston to collapses the piston into the caliper. Also open the master cylinder cap and place a towel around the area to catch any brake fluid that would come out of the master cylinder as you collapes the piston, this is normal, but doesn't always happen, depending on the level of fluid in the master cylinder. Install the new pads and reinstall the caliper and wheel. Make sure you pump the brake pedal a few times before you take off, to get the pads against the rotor.
1helpful
Soft Brake pedal on 1999 Mercury sable
first replace master cylinder the replace rear wheel brake cylinders.. Inspect front pads for non uniform wear, inspect front rotors replace if badly worn or scarred. You are dealing with 23-24 year old parts.
Where can I find a video on changing the front passenger side brake pads on a 2002 Sable?
On youtube. Also you never change just one side you always do both or your car will pull when braking.
My front passenger brake is sticking on a 1999 mercury sable
replace the brake hose as they can collapse inside causing the fluid to be trapped and not allowing it to travel back to the master cylinder causing a line lock effect.
Wheelbarrow on 201 mercury sable
The possibilities are depending on whether you hear the sound in the front or back of the car: You have a broken brake pad in the front or a broken brake shoe in the back; there is a bad wheel bearing that needs to be replaced, there is a flat spot on one of your tires.
How to change rear brakes on a 1997 mercury sable
Replace caliper with old brake pads put 1 bolt in place to hold together while taking a large screwdriver and prying caliper piston so that it compresses piston & block wedge to rear of bracket it should make enough room to install on new brake pads, the other way is to use a large c clamp put 1/4 pice of wood in between c clamp and caliper so you don't damage or Mar the caliper also check YouTube.
How do you get the capierer pin off to put front brake pads on my Mercury Sable LS?
Section 06-03: Brakes, Front Disc 1999 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Brake Shoe and Lining Removal
  1. Remove brake master cylinder filler cap (2162). Check fluid level in brake master cylinder reservoir (2K478) . Remove brake fluid until brake master cylinder reservoir is half full. Discard removed fluid.
  1. Raise vehicle on hoist.
  1. Remove wheel and tire assembly from front disc brake rotor mounting face. Use care to avoid damage or interference with disc brake caliper (2B120) , front disc brake rotor shield (2K004) or front wheel knuckle (3K185) .
  1. Remove rear brake pin retainers (2N386).
  1. NOTE: It is not necessary to disconnect hydraulic connections.
    Lift disc brake caliper from front disc brake caliper anchor plate (2B292) and front disc brake rotor (1125) . Do not pry directly against metal caliper piston or damage will occur.
  1. NOTE: To prevent damage, do not allow disc brake caliper to hang by the front brake hose (2078) .
    Position disc brake caliper out of the way.
  1. Remove inner outer brake shoe and lining (2001) assembly from front disc brake caliper anchor plate .
  1. Inspect both rotor braking surfaces. Minor scoring or buildup of lining material does not require machining or replacement of front disc brake rotor.
remove the 2 pins, #10 in pic. Usually has a dust cover over pin accessopening. Usually torx haed or hex head bolts (pins).
1997 Mercury Sable thumping in front end
try to replace the wheel bearings.
1helpful
3answers
Scraping pulse noise r front merc sable
Check the condition of the wheel bearings, front and back side if the brake rotor, and the back side of the rim. Everything should be clean, rust build-up can throw everything out of true. The hub or wheel-bearing should be tight and smooth when spun.
To many front rotor changes
make sure the caplipers are doing their job properly. if the calipers are not functioning properly that will cause uneven wear as well as a dragging, as in the pads are not coming off of the rotor and therefore rubbing while you're driving. also, check to see that you are getting a pad that will wear without so much rotor wear. they make pads that will absorb more wear so that you don't have to replace the rotors every time you have your brakes done. And if that doesn't work... no joke, change your braking habits. unfortunatly, to many people wait till they're at the stop sign or red light to apply the brakes instead of preparing for the known. my brakes have been on my truck (HEAVY) for 50,000 miles (hard use) and have only begun to squeak in the last 100 miles. Changed my brakes completely and my braking habits. good luck
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
