2000 Jeep Cherokee Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2000 Jeep Cherokee #7 10 amp fuse
Fuse keeps blowing out - It controls driver's side front & rear park light and side marker
Anonymous
Level 3:
President:
  • Master 1,608 Answers
  • Posted on Mar 16, 2010
Anonymous
Master
Level 3:
President:
Answers
1608
Questions
0
Helped
748429
Points
5514
You will have to check the positive wire of the wires that go to the parking and side marker lights for a short to ground.Check the easy things first like the bulbs for these lights.It could just be a shorted bulb.You can remove one at a time and see when the fuse stops blowing.You an get a short finder from a part store and save the trouble of getting a bunch of fuses.Hope this helps.Good luck.
2001 Jeep Grand Cherokee 4 l yesterday my brake lights out now today all my rear tail lights and brake lights are out?
WJ jeep USA.
fuse blown
or caused by trailer wiring rear, hitch, all mangled common
or past collision damged
front park lamps dead to or side lamps park dead/??????????????
only takes eyeball to see that.
or scan the PCM it will tell you why.
the service manual has the schematics for all that,
brakes + tail/park but blinks ok?
beside bad wiring, (I have A reAL WJ MANUALS ALL)
THE FUSE 6 IS BLOW
OR OFF F6 THE RELAY PARK IS BAD.
THE BCM BRAIN RUNS THE PARK RELAY TOTALY
SO BCM FUSES MUST NOT BLOWN, Just test all fuses. ?
BCM fuses are F7, f22, and f28, not blown./
the BCM must communicate on the network or fails
PCI bus is Jeeps name
if anything trashes this bus vast things fail.
if BCM is dead vast things fail over 25, and endless seeming list
not told you what does work? (telling only bad things only makes the job 10 x more hard.
scan and it tells you what is dead in 5min work. on most cars./.
1996 Grand Cherokee Laredo. Why does it have no running lights and instruments lights?
parks dead outside and inside dimmer side both dead.
fuses are first. lacking the manual we check them all.
I must assume front and rear parks and side parks are all dead.
and will answer only for that fact
the front feed makes dash lamps work too.
rear end , optional has lamp outage module to fail ,. only rear.
I have the shop manual for all GC .
USA?
XJ jeep
park wiring all (aka , tail lamps or running lamps but are the same feed)
feed means power feed.
chapter 8w is wiring all
fuse box PDC fuse 13 good.
pdc fuse 17 good
pdc relay park good. BCM runs this relay so the park switch to it must be good.
only in auto lamps
manual lamps turned on BCM is not in that path and Fuse 17 feed lamps direct via the HL switch ON.
if fronts/and front sides are dead, Fuse 17 blew.
if not the HL switch is bad.
I won't say, all wires to above can fail, that be obvious.
Rear park lights keep blowing fuse
first mistake you make is to increase the fuse capacity to above that required. You have a short in the circuit and by putting such a large fuse in you run the very real risk of burning the wiring loom. Check the bulb sockets and check that the right bulbs are in the sockets. bulbs come in two styles. one has 2 contact points and is either for 2 filaments (stop and tail) or a earth wire (Plastic light units) and the other is a single contact that earths out through the metal base . If you have the wrong bulb in place the current will short directly across the contacts and the light will not come on and the fuse will blow. Fuses for tail lights will be 5 amp maximun
94 Jeep Grand Cherokee 4x4 with the 4.0 Keeps blowing the fuse that controls the fuse box inside the jeep, its blowing a 40 amp fuse. I believe there is a short. but i don't where to look.
Get yourself a set of factory wiring diagrams,
otherwise your wasting your time
You have no idea what you working on, without
reference material
Helm.Com
1helpful
2004 jeep grand cherokee laredo keeps blowing the fuse for the parking lights and taillights
If it "keeps" lowing the fuse, there can be only one reason for it...you "keep" replacing the fuse without diagnosing the circuits to find out WHY the fuse is blowing in the first place.
When a fuse blows, there is a reason for it. If you do not find the reason and correct it, the fuse will continue to blow.
Please also review this article: Where's The Fuse?
With all of that said, the first thing I would check is all of the light bulbs. Sometimes the bulbs get really hot and melt inside and it causes the metal contacts in the bulbs to touch each other and short the circuit out. This is especially true if you can replace the fuse and everything seems to work ok for a while. They will all work until the offending bulb gets hot and "POOF" there goes the fuse again.
This condition can be hard to diagnose since the short circuit usually goes away as soon as the bulb cools off for a few seconds. In cases like this, what I usually recommend to save time and money is to replace all of the bulbs.
If it is fuse #6 (15 Amp) in the Central Junction Block that keeps blowing, it only powers the tail lamps, licence plate lamps, front park lamps and the front side marker lamps. The cost of replacing all of these bulbs is a LOT cheaper than an hour of diagnostic time at most shops. If this does not fix the problem, then you will have to trace all of the wires going to all of these bulbs to find out which one is shorting and where it is shorting. This could turn out to be very time-consuming and expensive, but at least, you will have eliminated the likelyhood that it is caused by a bulb.
1helpful
2answers
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
3helpful
2answers
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
BLOWS 10 AMP IGNITION RUN FUSE
the fuse blows because you have a short in any side you have to seek the court because the fuse continues to burn
1998 Jeep Cherokee blown fuse
Hello There
15 Amp sounds too small. It should be around 25 -30 Amp. You need to double check the size of fuse needed.
Hope this helps.
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
