Question about Neovo AG AG-01 TV Tuner Picture Frame Retail ***Free 2nd Day*** Graphic Card
Mitsubishi rear proj 1997 model 45-50in
Power light on but the picture will not come on and there is a clicking noise internally and a thumping sound from the speakers
    Scholar:
  • 126 Answers
It's a 1997 TV, I recommend buying a new one. If you have to get it repaired it will cost you more than the TV is worth.
Posted on Nov 16, 2008
I TOOK APART THE TV TO MOVE IT DOWNSTAIRS AND it worked great for 10 minutes and then shut down. I have the code and it is green and 2 and 2
That is called the "Parpadeo luz verde de la muerte" or Blinking green light of death. You may want to make sure all the wires are tight first and that when you moved it a cable wasn't seated. Instead of replacing the capacitors, your situation sounds more like bad solder connections on the DM module. Here is a link to a web forum where they talk about this exact problem.http://www.highdefforum.com/rear-projection-tvs/58189-blinking-green-light-death-frequent-prob-w-mitsubishi-rear-proj-widescreens.html Blinking Green Light of ***** frequent prob Mitsubishi rear proj...
Jun 25, 2015 | Mitsubishi WS-65413 65" Rear Projection...
I have a Toshiba 51h84.I push the power button and I get a solid red power light. There is a click from inside, kind of like a relay clicking on. No picture, no sound. If I leave it on I get an occasional...
Tv have "LAMP" indication LED light blinking?The tv projection lamp is dead,require changing.Hearing alot of clickings sound too?Mean the board,call the Ballast board is dead.Require change the Ballast too.The Ballast board,the board that help to ignite the projection lamp.
Aug 06, 2010 | Toshiba 51H84 51" Rear Projection...
Blinking Green Light Mitsubishi TV
I had the power supply replaced, but didn't solve the problem. Turns out multiple issues were at play. Only thing that solved the problem was to the have the chassis pulled and rebuilt by Mitsubishi. If you are insistent enough they should do it for free, minus the labor for removal and re installation (approx.$300)
Oct 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green light at start up but green light goes off
sounds like your lamp may have gone out. check your manual as to changing lamp.
Sep 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Test
Ballast Lamp provide back light in DLP TV and if its bad / broken TV wont power up. If lamp is weak, dark or less bright picture will come in screen. Color wheel is responsible for colors in picture and if its broke, TV wont power up and common problem with color wheel is high pitch noise while it spins.
Jun 12, 2009 | Sharp 65DR650 65" Rear Projection...
No picture or sound,clicking in back and speakers thump to clicking noise
Tubes are messed up, to fix is REALLY expensive, trash it or part out what can still be used.
May 21, 2008 | Mitsubishi VS-6043 60" Rear Projection...
No picture or sound
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Akai pt4298hd rear proj tv
Unit may be in timer mode. Check menu settings
Apr 22, 2008 | Akai PT4298HD Rear Projection Television
Sony REar Proj. mOdel KP61HS10
I may be able to help you figure this out. My specialty is Sony, mitsubishi and panasonic. Are you planning on repairing the TV yourself, Can you solder? Let me know .
Jan 13, 2008 | Televison & Video
No responce except thumping noise
PLEASE TRY TO CHANGE AGAIN THE CONVERGANCE IC'S
Oct 02, 2007 | JVC AV-48WP30 48" Rear Projection...
Computers & Internet Logo
54 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
