Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Door not locking
Would appreciate step by step instructions on door latch install
  • 5,911 Answers
Here ya go. Read through the instructions carefully before beginning any disassembly. This repair is not difficult as long as you follow these steps:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO **T remove the rubber bellow from the wash tub. This requires more steps, which means removing more parts, which means more time (plus patience).
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom.
Once you've completed these steps make sure the door closes and latches properly. ***** slam a door with an electronic latch. They can break easily.
Now plug the washer back in. At the control panel select:
DRAIN SPIN
** SPIN
and under OPTIONS press any key (has the be the same key) 4 times.
This places the washer into diagnostics mode. "C00" will be displayed on the screen and you should hear a distinctive "click" of the door latch. If diagnostics passes, the washer will run through a series of tests, tumble, drain and then spin. When completed, the unit will make an audible "beep" and the CLEAN light will be lit.
You can stop this process at any time by press the PAUSE/CANCEL button. Good luck to you and let me know if you have any further questions.
Posted on Mar 09, 2008
  • 1 more comment
  • Jeff Rockwell
    Jeff Rockwell Mar 09, 2008
    PS something happened to some of the text after I posted this. In paragraph 3. the asterisks should read "**". The instruction should read, "DO **T remove the rubber bellow from the wash tub". In paragraph 8., The four asterisks **** should say "DO **T" as in DO **T slam a door... The asterisks listed under DRAIN SPIN, should read "** SPIN". Sorry for any confusion.
  • Jeff Rockwell
    Jeff Rockwell Mar 10, 2008
    The problem seems to have been resolved on the comment posting issue. Just for your info: Anywhere there is a set of asterisks in this posting "**", should be an N O.
  • lynnisse Feb 27, 2011
    This works for the Kenmore HE3t 110.42922.200! Piece of cake. No need to remove the front panel or the door. Thanks!!
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
Error Fdl on kenmore
This is a door latch problem. Check the door itself and make sure it is shutting all the way. Sometimes the hinges bend slightly or the door becomes loose which prevents the door latch from locking. If the door is OK I would recommend replacing the door latch.
Nov 01, 2012 | Kenmore Elite 45986 Front Load Washer
WE have Kenmore elite He3t Model Nol. 42926 203. We get an error code dL F. How do we correct this?
It is a door lock failure and it flashes after the door locking routine fails to lock the door after 6 attempts. Replace the door lock/latch assembly (part number 8182634) to solve the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Jan 07, 2011 | Kenmore Elite 45986 Front Load Washer
Door latch to Kenmore Elite Oasis gas dryer has come loose. It will not close properly in order for dryer to start. Need instructions on how to repair or replace latch piece on door.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How to replace door lock on my kenmore elite washer he3
The following link explains step-by-step how to replace the door latch on a Kenmore Elite HE3:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
This is a very simple repair. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 07, 2009 | Kenmore Elite 45986 Front Load Washer
Door is open but lock is in the lock position
There is a manual lock release on the bottom of the door latch. Remove the bottom kick panel by removing three 9/32" screws from along the bottom, then reach inside the washer, up to the door latch. You should feel a small plastic tab on the bottom of the latch, pulling this tab should release the lock. If this does not help, you may need a new door latch. If that is the case, re-post and I will list simple steps to replace the latch, if needed. Hope that helps.
Apr 21, 2009 | Kenmore 46462 Front Load Washer
DOOR WONT LOCK KENMORE ELITE HE4T
Before removing try some WD40 spray on the door mechanism, not on door.
Aug 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite door latch
Here ya go. Try this link:
If you're still having problems, please let me know. I hope this helps you.
Aug 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t Washer door won't lock
Im assuming that the part number youve mentioned is for the new door latch assy?? Unfortunately the problem could also be in the Main CCU. Ive had several of this design have intermittent door lock codes and not lock the door....It was the CCU in most. This washer should have a full years warranty for parts and labor. Perhaps the sears people didnt understand its still under warranty. I wouldnt want for you to waste your money on the door latch if it is the Main computer. Also you may want to remove the top of the machine and check the wiring connectors going to and from the CCU and the latch.
Nov 25, 2007 | Washing Machines
Kenmore Elite problem
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^@#
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
