Symantec Norton Internet Security 2009  Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It keeps on coming back and its hard to delete.
Anonymous
Level 2:
New Friend:
  • Expert 89 Answers
  • Posted on Mar 15, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
89
Questions
0
Helped
18821
Points
276
Are you trying to remove norton? if so, you can this. if you're trying to remove a spyware or virus infection using your norton and is unable to do it, use this.
How do I permantly delete pictures from the Gallery on my Virgin Mobile Event phone?
Hello Jody,
Are you currently using a Micro SD storage card in your Virgin Mobile device? If so, you may have to enter your internal setting and delete the photos from the storage device.
If not, you may attempt to delete the photos and then perform a hard reset on your Virgin Mobile device, either by removing the battery for ten seconds or pressings and holding the power/lock screen button until the device powers off.
Thanks,
Dish Guy
tip
How to remove unwanted files from your hard drive to increase computer speed and...
This instruction will help you remove unnecessary files from you hard drive. Generally these are temporary files that the computer generates whenever you perform a task on the computer. An example would be searching the internet and making a word document. Follow the instructions below on a regular basis to keep unwanted files from clogging up your hard drive.
Double Click on My Computer, you will open a window showing all your drives.
Right click the “C” Drive, you will get a menu
Click on Properties
Look for “Disk Cleanup”
The system will start searching for unneeded files
A window will come up showing a list of files that can be deleted
Delete Temporary Internet Files, Temporary Files, Cookies and a any other files you recognize as unnecessary.
Click OK and the files will be deleted.
Keeping your hard drive uncluttered as much as possible will help keep your PC functioning at peak capacity.
I hope that you have found this tip useful.
on Jan 25, 2010 • Computers & Internet
My computer keeps saying "The last attempt to restart the system from its previous location failed. Attempt to restart again?"
When you boot up, try pressing the delete key to see if that will take you to the bios setup screen. See if the computer recognizes your hard drive, and make sure that it is in the boot sequence. If your hard drive isn't there, it's fried and you have to buy a new one. Next, put your windows disk in your hard drive and see if you can boot from there. There is an option to repair windows if your hard drive is ok. Worst comes to worst, try reinstalling windows. You will loose all your data, but might get the computer back. It's a good idea to keep all important data backed up on a usb drive.
OVI Store had been deleted from my E63 nokia handset. Pls tell me how can i restore the same at my NOKIA E63 handset
using any of these 3 ways,you will lose information,unless you back up to memery card 1st.
type *#7380# is the soft reset,(not always work)
type *#7370# is the hard reset(not always work)
or theres a full format,that will delete all data,,so back your phone +memery up 1st..
switch phone off,1st.then(remember this put your mob bac to when you 1st had it,unless you back up to memery card 1st:)
press * and 3 together ,and keep them pressed,,while you press them,,press power on,,and keep all 3 pressed in untill you see the nokia logo,,,then release just the power on,,keeping the other 2 pressed in,,untill you see mob asking which country.....realse then...that will work on all n series and e series,and any symbian nokia mob.
when mob comes on to main screen,your backup will start installing.
Nov 09, 2010 • Cell Phones
I forgot my password and i want a new number please delete my password it should bea1b2c3 but it said its incorrect what should i do write back
The only way I know to bypass the password request riytube is hard resetting your device. You, most probably, know that a hard reset sets your phone to its factory defaults, thus deleting all your personal data, as well as the applications you have installed. To hard reset your device, firstly, turn it off. Then, press and hold the ENTER key. Whilst keeping this key pressed, briefly press the POWER button. Release the ENTER key when a warning screen comes up. Then, press the VOLUME UP button to hard reset your device, or any other key to cancel the hard reset procedure.
Hope you are able to have your device fully functional again.
Cheers!
Carlos
Keeps Copying
transfer is the problem...
you simply want to select the photos you want to send
and then send them to my pictures and maybe put them in new folders .
do not copy and send, that is where the coping is coming from.
Hope this helps
AUTOMATIC BACKUP TO EXTERNAL HARD DRIVE (FIRELITE)
The first thing that comes to mind is the Firelite has become full and can not accept any more backup data.
Delete the data on the Firelite and try running your backup again. If it works then that was the problem.
The backup software should have a configuration setting somewhere that allows it to automatically delete older data and keep it from filling up.
Top Symantec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
