Question about RCA OPAL M4001 MP3 Player
Connection Problem When Opal is connected to usb port it may be recognized for a second or two then disappears, it's there than it's not. This happens on different compters. Cable does not seem to be loose. This unit has barely been used.
  • 1 more comment
  • techdumb2008 Mar 09, 2008
    RCA Opal m4002A
  • Freaque Mar 13, 2008
    I have attempted connecting and reconnecting the USB cord but nothing seems to work. The computer will not read it. Also, whenever I take out the cord the OPAL says that there is an error and shuts down.
  • terrydog Apr 23, 2008
    opal mp3 sometimes charges,sometimes is recognized and transfers new music, but here lately does not do either. When I connect it, it just comes on and starts playing music, the computer does not recognize it.
Mine did this...i did this
1) Plug it in to the computer
2) Grab the end of the cord near the Player
3) Pull the cord BEHIND THE PLAYER SO THAT YOU CAN STILL SEE THE WHOLE SCREEN
4) Pull the cord TIGHT
This seems to work for me...i used tape to hold the cord tight to the back of the blayer
Posted on Sep 16, 2008
You missed the part about "it does this on different computers."
I'm guessing this is the same problem that I have, which is an internal problem with the "headset" jack (I say "headset" because it is also the jack used to connect to the computer...). I haven't tried contacting RCA directly about this problem, but essentially the solder or some other point of the connection is loose. An actual solution I am unaware of, but I will soon ask RCA if they have a repair process (or I will just open it up and resolder it myself).
Posted on Mar 25, 2008
Try using a differnt computer mine did the same thing for some reason it wont work in a low speed usb port it has to be high speed
Posted on Mar 13, 2008
Windows vista does not acknowledge Opal M4002a
If the player is not recognize try to connect the mp3 player ona different usb port and check if it will be detected if still not detected better connect this mp3 player to another pc and check if it will be detected on that second pc if not detected there's a possibilty that the mp3 usb functions is not working fine.
Jun 20, 2008 | RCA OPAL M4001 MP3 Player
Hung in a transfer loop after being removed from PC
When I (USB) plug in my RCA Opal M4002A mp3 player into my "Office PC" it works fine, but when I plug it into my "Studio PC" the "Opal" screen shows "USB connected" and so does the "PC" with the "Device Connected Sound" but then the "Mouse Pointer" changes to the "Hour Glass" you hear the "System Notification Sound" then the "Mouse Pointer" changes back to the default "Arrow Pointer" and this back and forth action loops endlessly until I unplug it. I've tried everything. Any ideas would be greatly appreciated. Thank You, Quaal
*** ONLY THIS PART OF THE ABOVE MESSAGE IS MINE ***
ALSO I HAVE THE "RCA Opal M4002A" (2GB) mp3 player.
*** After much trial and error this FIXED my problem. ***
1 - First right mouse click on "My Computer".
2 - Left click on "Properties"- Left click on "Hardware"- Left click on "Device Manager".
3 - Now with one end of the USB cable plugged into your mp3 player, plug the other into your USB port. (Now when I did this a new "Portable Device" icon with an "MTP" Driver (sub icon) showed up in the "Devices List". (The "MTP" icon had an "!" on it, telling my it wasn't working properly. I then did this.
4 - Right click on "MTP" driver icon, then ...
5 - Left click on "Update Driver". (I was then given two choices. The top one was the faulty "Portable Device" driver which I had done everything I could to fix, but nothing worked. So I then did this ...
6 - Left click on the "Mass Storage" Driver (the second choice below it in the list), I then clicked "OK". The "Updating Driver" screen showed for a moment. The "Portable Device / MTP Driver(!)" icon vanished from the "Device Manager" devices list, But the looping STOPPED!!! My Opal was working beautifully and showing in my "Root Directory" as Drive j: and in "Device Manager" under "Disk Drives" as "Thomson Opal USB Device".
P.S. For some reason the file transfers are noticeably faster now. Good Luck, Quaal
May 21, 2008 | RCA OPAL M4001 MP3 Player
No device recognized when connected to computer
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 13, 2008 | RCA OPAL M4001 MP3 Player
Rca opal M4008A mp3 player
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Feb 08, 2008 | RCA OPAL M4001 MP3 Player
Whenever i try to turn my opal on, it always says please reformat me. i tried the download but it just keeps on searching for the device.
Feb 07, 2008 | RCA OPAL M4001 MP3 Player
Connecting
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (moz-screenshot.jpgmoz-screenshot-1.jpghttp://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
Same thing
Feb 06, 2008 | RCA OPAL M4001 MP3 Player
Rca opal m4018a
Feb 02, 2008 | RCA OPAL M4001 MP3 Player
RCA OPAL M4002A ERROR MESSAGE
RCA Opal troubleshooting
Make sure the Hold Button - it's on the side of the Opal - is off.  When the hold button is on, it makes the Opal think the Flash disk is full, and you get all kinds of wacky reactions.
Hope this helps...
Dec 01, 2007 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
60 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
