I am not a young person... i believe that weather is caused by more then one variable... be it from the Sun's energy... or from something called Smog... or pollution... or simply... changes just happen, because it's happened before... and we go thru cycles... cycles that are longer in time then your typical lifespan.
I believe people will have an agenda to exploit climate for their own cause.
Elderly people buying unhealthy food may not be a matter of choice... but in reality the result of economics.
I dont know what to tell you about the double bagging... maybe consider getting her a reusable sack for her groceries...
If she refuses, then maybe it's time to ask her directly... if she responds kindly then maybe you have a chance to turn her around...
If she is rude or less then kind, then express that you are concerned.
Hopefully she will appreciate someone that cares for her.
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/lisa_52daba487e5b4d53
RTOs will use either a forced draft or induced draft fan system, depending on the process air temperature. Installing the fan on the coolest side offers the best performance. regenerative thermal oxidizer suppliers
